Pitot mast tie down clearance
digidocs
PostPosted: Tue Oct 17, 2017 2:27 pm    Post subject: Pitot mast tie down clearance Reply with quote
Hi guys,
Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank?
That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank):
https://tinyurl.com/y76l4cq3
David
philperry9
PostPosted: Tue Oct 17, 2017 2:59 pm    Post subject: Pitot mast tie down clearance Reply with quote
I’ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they’re narrow, then yeah. If they’re wide, then no.
But if I moved the mast outboard I’d still have problems at those places too. So it’s as broad as it is long.
I don’t think it’s worth the trouble to reinvent a location and move it from the standard location.
On Oct 17, 2017, at 5:25 PM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
Hi guys,
David
Tim Olson
PostPosted: Tue Oct 17, 2017 3:28 pm    Post subject: Pitot mast tie down clearance Reply with quote
I did the same....pitot is one bay further out.
On Oct 17, 2017, at 5:57 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Hi guys,
David
dmaib(at)mac.com
PostPosted: Tue Oct 17, 2017 5:01 pm    Post subject: Pitot mast tie down clearance Reply with quote
Mine are in the standard location and I’ve never had any tie down clearance issues in 9 years and nearly 1000 hours. Narrow or wide doesn’t seem to make a difference. I figured Van’s had flight tested the prototype with the pitot in that location, so the odds of having pitot/static accuracy issues would be minimized if I followed the plans on that particular issue.
David Maib
40559
985 hours
On Oct 17, 2017, at 6:57 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Hi guys,
David
philperry9
PostPosted: Tue Oct 17, 2017 5:09 pm    Post subject: Pitot mast tie down clearance Reply with quote
It’s not an accuracy issue. It’s the rope running into the pitot tube of the tie down points on the ground are narrow....
On Oct 17, 2017, at 8:00 PM, David Maib <dmaib(at)mac.com (dmaib(at)mac.com)> wrote:
David Maib
40559
985 hours
Hi guys,
David
dmaib(at)mac.com
PostPosted: Tue Oct 17, 2017 5:19 pm    Post subject: Pitot mast tie down clearance Reply with quote
I understand the issue. Just putting in my $.02 worth and stating why I made the decision at the time.
David Maib
On Oct 17, 2017, at 9:08 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
It’s not an accuracy issue. It’s the rope running into the pitot tube of the tie down points on the ground are narrow....Sent from my iPhone
David Maib
40559
985 hours
Hi guys,
David
