Battery charger / power supply
art(at)zemon.name
PostPosted: Sun Oct 22, 2017 3:58 pm    Post subject: Battery charger / power supply Reply with quote
Would this be good for my plane after I have an engine and for testing the panel now?https://m.harborfreight.com/2815-amp-automatic-microprocessor-controlled-battery-charger-63299.html
    -- Art Z.
Sent from my phone. Please excuse brevity and bizarre typos.
cluros(at)gmail.com
PostPosted: Sun Oct 22, 2017 4:26 pm    Post subject: Battery charger / power supply Reply with quote
The problem I see with that charger Art is that it will not act as a power supply. If you want to test the panel or power the aircraft, that charger will turn itself off automatically if it sees the drain.
I would go with something like this that has a power supply mode. This one will supply 5A continuously while you work. If I'm going to have the master on more than a couple minutes I plug it into ground power to support the battery.
https://www.amazon.ca/NOCO-G7200-7-2-Amp-Battery-Maintainer/dp/B004LWTHP2/ref=sr_1_1?ie=UTF8&qid=1508718168&sr=8-1&keywords=genius+charger+7200
On Sun, Oct 22, 2017 at 4:56 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
    -- Art Z.
skywagon
PostPosted: Sun Oct 22, 2017 4:45 pm    Post subject: Battery charger / power supply Reply with quote
Hi Art,
I think you are asking 2 questions about battery and panel test.
If you are just trying to keep a good battery charged/maintained, there are several low cost "maintainers" out there. Harbor F. has one for about $5 - 10, depending on their crazy sales ads. It is small and works for "maintaining" only. Not for charging a flat battery or testing panels as its current ability is too low.
The only detail to note in its use... is to measure the float voltage once it has stabilized the charging level of the battery. My suggestion is that it should "float" about 13.2 to 13.4 v. Others may disagree.  If it is not that, save your receipt, return it and get another unit. The older style units, with a little case modification, could be adjusted to the correct voltage range. Not sure the current models can be adjusted.
Now, for general charging/maintaining and panel testing, I believe the unit you suggested should work fine. Keep in mind that it's top current ability is 15 amps. So, don't fire up the panel and accessories to more than approx. 12 amps or so.
All should be fine. Let us know if use this unit how it performs. . . .
Dave
jimkale(at)roadrunner.com
PostPosted: Sun Oct 22, 2017 9:04 pm    Post subject: Battery charger / power supply Reply with quote
I read with interest the battery charging information.
I agree that a battery charger/maintainer is the way to go.
I do not get the cheap (made in China battery chargers) the life expectancy of some of the cheap parts in them is too much of an issue for me.   All it takes is for a resistor, or capacitor to go out and the charger to go into a high voltage mode and you have a melt down on your battery.   It could possibly catch fire and burn your airplane up.
I pay a little more and get one of the high quality BATTERY MINDER charger/maintainers.  They have a proven reputation and are built with high quality parts.  They also have circuits to prevent high runaway voltage just in case one of the critical parts fail.
Think about what you are risking with a battery charger malfunction.   Fortunately, most of the time, if there is a part failure, they just shut down, and drain your battery to zero.  Then you get to buy another battery and another charger.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Art Zemon
Sent: Sunday, October 22, 2017 6:56 PM
Subject: Battery charger / power supply
-- Art Z.
art(at)zemon.name
PostPosted: Mon Oct 23, 2017 3:08 am    Post subject: Battery charger / power supply Reply with quote
Having gotten home from dinner (so I'm no longer surfing the HF website on my phone) and slept (so I'm more rational), I reread the Batteries chapter of the AEC. Based on what I read this morning, it is time for me to buy the battery(ies) for my plane and a trickle charger. I'll let the battery supply the higher current for testing the panel and then let the charger replenish the battery at a lower current.
Cheers,
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
ceengland7(at)gmail.com
PostPosted: Mon Oct 23, 2017 7:02 am    Post subject: Battery charger / power supply Reply with quote
Cheers,
    -- Art Z.
https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
I'm getting the impression that we might be talking about leaving the charger on the battery all the time. There's a lot of empirical evidence for that being a bad idea, even with a 'smart' 'maintainer' style charger. AGM batteries have very little self-discharge over time, so they don't need to be 'maintained'. As an example, my 4+ year old AGM battery in my RV-4 often sits for over a month without being flown, but it starts the plane just fine after sitting. On the other hand, there have been numerous posts on this and other lists/forums by people who've left a 'smart maintainer' style charger hooked to their AGM battery and had the battery die a very premature death. It's extremely rare to hear about early death when the battery is just used normally.
Charlie
PostPosted: Mon Oct 23, 2017 7:10 am    Post subject: Battery charger / power supply Reply with quote
That will work. My current favorites for $value$ in
small charger/maintainers are the Schumacher SEMI1562A
http://tinyurl.com/y8o3ryb5
or Battery Tender Jr
http://tinyurl.com/y8dzte5o
I have both of these products in service
in my shop and I have installed them on
farm equipment for several friends.
Left plugged in and connected to your
ship's battery at all times, you can use
the battery for short interval testing
(say 30 minutes to a hour) in the battery-
only, endurance mode. The charger will
have the battery topped back off by
the next morning.
The Schumacher has about 2x the output of the
Battery Tender so it will top off a bit
quicker . . . but both will do the job.
For extended ground ops on the airplane,
consider something like this:
http://tinyurl.com/ycg5uuf3
This can be floated across the ship's
battery but should not be used to charge
a depleted battery.
art(at)zemon.name
PostPosted: Mon Oct 23, 2017 7:23 am    Post subject: Battery charger / power supply Reply with quote
Charlie,
For now, I will use the battery for testing the electrical devices in the plane while I am assembling it. I will use the charger to recharge the battery since the plane does not (yet) have an engine.
    -- Art Z.
On Mon, Oct 23, 2017 at 10:05 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Cheers,
    -- Art Z.
Charlie
[/url] Virus-free. [url=https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link]www.avast.com [url=#m_6940801807452127696_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
art(at)zemon.name
PostPosted: Mon Oct 23, 2017 7:32 am    Post subject: Battery charger / power supply Reply with quote
On Mon, Oct 23, 2017 at 10:09 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  the next morning.
​Yup. That's exactly what I have in mind. I won't have the big-current stuff turned on at all. Radios won't be transmitting. Lights won't be on more than momentarily. Pitot heat not on. Etc.
Cheers,
    -- Art Z.​
cluros(at)gmail.com
PostPosted: Mon Oct 23, 2017 7:36 am    Post subject: Battery charger / power supply Reply with quote
Charlie, I'm not sure "starts the plane just fine" is a good metric of battery health. This summer my one year old AGM battery started the plane fine 3 times in one day right before it self discharged to 10V in 4 days.
Sebastien
On Oct 23, 2017, at 08:05, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Cheers,
-- Art Z.
Charlie
PostPosted: Mon Oct 23, 2017 8:12 am    Post subject: Battery charger / power supply Reply with quote
No argument to the bare statement, but it's barely tangential to the subject at hand. And nowhere near enough data to know what happened to yours. Did you leave it on a trickle charger all the time? Was the charging system in your a/c working properly? Was your battery defective?
I had one that died after about the same length  of time. When I pulled the cowl to check it, there was a pinhole in the side of the battery; obviously done in shipping (or in the plant) almost a year earlier. It had been slowly puking acid vapors out that 'vent' since new. Worked fine until it didn't.
On Mon, Oct 23, 2017 at 10:35 AM, Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
Sebastien
Cheers,
    -- Art Z.
Charlie
Virus-free. www.avast.com [url=#m_-3109937323447436738_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
