Rotax 914 TCU interface
Peter(at)sportingaero.com
PostPosted: Sat Oct 28, 2017 3:29 am    Post subject: Rotax 914 TCU interface Reply with quote
Does anyone have any experience with the Rotax 914 Turbo Control Unit interface app?
I know the TCU has the on-board adapter and a straight RS232 interface lead will work.
Where is the interface software obtained from?
The TCU in question is flashing the yellow light, meaning an airbox/throttle position sensor is broken/disconnected.
Apparently this app will indicate which sensor to look at.
Is the software straight forward to use?
Thanks in advance,
Peter
gilles.thesee(at)free.fr
PostPosted: Sun Oct 29, 2017 1:53 am    Post subject: Rotax 914 TCU interface Reply with quote
Le 28/10/2017 à 13:27, Peter Pengilly a écrit :
<![endif]--> <![endif]-->
Hi Peter,
Have you tried this ?
http://www.flyrotax.com/services/technical-documentation.html ?
Also some info here
http://www.rotax-owner.com/en/rotax-blog/item/45-64-bit-tlr
Your computer must have a genuine Series port.
The software is a bit crude, but it works, some basic info is available in the Rotax Installation Manual.
We had some issues last year, and zeroed in on the wastegate binding on power on due to lead deposits.
Hope this helps,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
