kingsnjan(at)westnet.com. Guest
Posted: Fri Oct 27, 2017 3:25 am Post subject: Europa Cowl Resin |
Is anyone able to advise what Resin is used on the Europa cowls please?
Kingsley in Oz
pjeffers(at)talktalk.net Guest
Posted: Fri Oct 27, 2017 5:52 am Post subject: Europa Cowl Resin |
Hi Kinbsley,
The answer is the same as the rest of the aircraft.
Not the blue stuff!!
Pete Jeffers
Sent: ‎27/‎10/‎2017 07:33
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Europa-List: Europa Cowl Resin
--> Europa-List message posted by: Kingsley Hurst <kingsnjan(at)westnet.com.au>
Kingsley in Oz
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
spcialeffects
Posted: Fri Oct 27, 2017 7:33 am Post subject: Re: Europa Cowl Resin |
Kingsley, am I right in saying you have a classic? with classic cowls? If yes then originally the cowls would have been layed up with ampreg 20 which has now been super seeded by ampreg 21
Regards Frank Xuereb kit#165, just waiting testing
Remi Guerner
Posted: Fri Oct 27, 2017 11:53 pm Post subject: Re: Europa Cowl Resin |
I remember reading somewere that non structural parts of the XS, including the cowling, were made of polyester, not epoxy. I also suppose a high temperature stuff is needed for those parts. Has anyone the right answer?
Remi
Posted: Sat Oct 28, 2017 3:36 am Post subject: Europa Cowl Resin |
Thank you Pete and Frank and yes Frank, I do have the Classic cowls.
Strangely, the inside of my cowls are still a nice pale green colour with no
yellowing like other parts of the airframe. I have always been of the
opinion they might have some phenolic base in them and when I have cut them,
I reckon it smelt very much like polyester.
Thanks again men . . . . onwards and hopefully Upwards!
Kingsley
Fred Klein
Posted: Sat Oct 28, 2017 9:12 am Post subject: Europa Cowl Resin |
Quote: | On Oct 28, 2017, at 4:35 AM, Kingsley Hurst <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)> wrote:
I have always been of the opinion they might have some phenolic base in them and when I have cut them, I reckon it smelt very much like polyester.
Kingsley…I believe you’re correct but have no way to confirm…F.
Nigel Graham
Joined: 23 Mar 2017 Posts: 36 Location: Winchester - UK
Posted: Sat Oct 28, 2017 2:57 pm Post subject: Re: Europa Cowl Resin |
Remi is correct. All the grey coloured components supplied with the original kit (cowls, doors, "D" panel and the speed kit) were manufactured with woven glass and polyester resin.
If you need a heat tolerant polyester resin for cowling mods, use a "tooling" grade product. These are designed to withstand autoclave temperatures and have minimal shrink characteristics. I use "Optimould".
Hope this helps
Nigel
peterz(at)zutrasoft.com Guest
Posted: Sat Oct 28, 2017 4:22 pm Post subject: Europa Cowl Resin |
Thnks for that info! That means any door strut mods need to be done in poly and not epoxy then? I've not heard that to date....or maybe i wasnt listening
Cheers and thx,
Pete
Quote: | On Oct 28, 2017, at 6:57 PM, Nigel Graham <nigel_graham(at)m-tecque.co.uk> wrote:
Hope this helps
Nigel
http://forums.matronics.com/viewtopic.php?p=473917#473917
brian.davies44(at)gmail.c Guest
Posted: Sun Oct 29, 2017 1:09 am Post subject: Europa Cowl Resin |
My understanding is that it is perfectly acceptable, and maybe even
desirable, to use epoxy resin on cured polyester surfaces. It is not
acceptable to use polyester resin on cured epoxy surfaces because it does
not bond well that way round.
Brian
Duncan McFadyean
Posted: Sun Oct 29, 2017 1:53 am Post subject: Europa Cowl Resin |
The pale green colour gives away that the resin is probably Class 2 fire retardant (polyester), which is what I have believed it to be, having been told that by the company that made the Classic cowls; others might be different.
It might also be vinyl-ester, but I doubt it and this resin is now in any case very difficult to track down in Class 2 quality (Dow used to supply it, but don't appear to any more).
Standard Class 2 polyester can be post cured to a Tg of up to 80C, which is more than enough for cowls (other than close to inappropriately fitted/protected manifolds, which can/should be dealt with by other means). There would be other issues under the cowls at 80C to worry about!
Duncan McF.
Quote: | ----Original Message----
Date: 28/10/2017 12:35
Subj: Re: Europa-List: Re: Europa Cowl Resin
--> Europa-List message posted by: "Kingsley Hurst" <kingsnjan(at)westnet.com.au>
Thanks again men . . . . sp; - List Contributinbsp; &=
Fred Klein
Posted: Sun Oct 29, 2017 3:44 pm Post subject: Europa Cowl Resin |
Quote: | On Oct 29, 2017, at 2:07 AM, Brian Davies <brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)> wrote:
My understanding is that it is perfectly acceptable, and maybe evendesirable, to use epoxy resin on cured polyester surfaces.
Thank you Brian…that’s a relief in that I’d added epoxied mods to my doors…which seem to be holding up well…F.
Posted: Sun Oct 29, 2017 10:32 pm Post subject: Europa Cowl Resin |
Many thanks Nigel and Duncan. You have confirmed my suspicions and enlightened me which by the way, is not hard to do!
Thanks again men
Kingsley
