1james.baldwin(at)gmail.c Guest
Posted: Tue Oct 31, 2017 5:58 pm Post subject: ADS-B Antennae |
I am hooking up my Grand Rapids Technology ADS-B hardware and two of
the connections are coax. I asked and they said either RG58 or RG400
works.
1. Should I use one or the other for some reason?
2. I can't thread a completed coax where it goes with connectors so I
need to fasten or crimp them on afterwards. Anyone using a tool
available at Lowe's or HD or Fry's or ...?
3. I went to Lowe's and didn't see any RG58 wire or connectors. I saw
they had RG59 whatever that is. I did see RG58 A/U at Aircraft Spruce.
Hints appreciated. Thank you. JBB
Kellym
Joined: 10 Jan 2006 Posts: 1700 Location: Sun Lakes AZ
Posted: Tue Oct 31, 2017 7:56 pm Post subject: ADS-B Antennae |
Crimp tool:
http://www.steinair.com/product/ratcheting-crimper-frame-only/ and
http://www.steinair.com/product/bnc-crimp-die-only/
Do not try to use TV or automotive crimpers.
If your run is about 6 ft or less, you can use RG58 of the stranded wire
center conductor variety. I suggest RG-400 for your transponder/ADS-B
Out transmitter. RG-58 will do the job for the ADS-B In receiver, as
well as for your com radio(s).
RG-58 and RG-400 are 50 ohm impedance, which you want. RG-59 is 75 ohm
impedance and usually solid core center conductor.
On 10/31/2017 6:56 PM, James Baldwin wrote:
Quote: |
<1james.baldwin(at)gmail.com>
works.
KCHD |
wrmaxwell(at)bigpond.com Guest
Posted: Tue Oct 31, 2017 9:01 pm Post subject: ADS-B Antennae |
RG59 is 75 Ohm coax, used in video/tv applications. RG400 is higher spec 50 ohm coax. RG58 is the more common. For short runs, RG58 is normally adequate.
On 1/11/2017 12:56 PM, James Baldwin wrote:
Quote: | --> AeroElectric-List message posted by: James Baldwin <1james.baldwin(at)gmail.com> (1james.baldwin(at)gmail.com)
I am hooking up my Grand Rapids Technology ADS-B hardware and two of the connections are coax. I asked and they said either RG58 or RG400 works.
2. I can't thread a completed coax where it goes with connectors so I need to fasten or crimp them on afterwards. Anyone using a tool available at Lowe's or HD or Fry's or ...?
3. I went to Lowe's and didn't see any RG58 wire or connectors. I saw they had RG59 whatever that is. I did see RG58 A/U at Aircraft Spruce.
rene(at)felker.com Guest
Posted: Wed Nov 01, 2017 5:00 am Post subject: ADS-B Antennae |
If you have your cable lengths….just call Stein and have him make the cables with RG400. If time is money, it is the best way to go.
If they have to be made in place…..
I used RG400…..
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Maxwell
Sent: Tuesday, October 31, 2017 11:00 PM
Subject: Re: ADS-B Antennae
