Need latest Navworx UAT Console
Mauledriver(at)nc.rr.com
PostPosted: Thu Nov 02, 2017 7:04 am    Post subject: Need latest Navworx UAT Console Reply with quote
I have the Navworx unit that will work with the AMOC given a certified
GPS source.  But I don't have a copy of the UAT console that will run,
looking for help.
I tried running the UAT console software I obtained back in 2012 but get
an error on loading, "Nonshared DATA segment required", then if fails to
open.  Anyone have experience with this?
A secondary concern I have is that I recall the UAT console loads a
version of the Navworx software.  If so, this is backlevel for my box
(my box had been sent in since then for a maintenance upgrade).
Does anyone have a copy of the UAT console that they can share or
otherwise advise?  Thanks.
(I'll be posting on the VAF board as well)
Bill "wired up G430w to the deadend box with all appendages crossed" Watson
Tim Olson
PostPosted: Thu Nov 02, 2017 7:14 am    Post subject: Need latest Navworx UAT Console Reply with quote
I have version 4.1.0 if you need. You're right that if you run
the app, it will upgrade your firmware. Mine is far newer
than 2012, but not the 5.0 that Bob talks about.
I have seen one person who couldn't get it to load on their
system, due to an issue with the system, but I was able to load
it on 3 of them.
looking for help.
rleffler
PostPosted: Thu Nov 02, 2017 7:39 am    Post subject: Need latest Navworx UAT Console Reply with quote
If you need 4.1.0 and the manual, let me know.
I haven’t been able to locate anyone that has 5.0 yet.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Bill Watson <Mauledriver(at)nc.rr.com>
Sent: Thursday, November 2, 2017 11:01:53 AM
Subject: Need latest Navworx UAT Console
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
looking for help.
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p;   -Matt Dralle, List Admin.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Thu Nov 02, 2017 8:22 am    Post subject: Need latest Navworx UAT Console Reply with quote
The Mauledriver email is just for posting.
My email is BillisinDurham - gmail  (without the 'is').
I have the current manual from the Dallas folks.
Thanks all!
looking for help.
get an error on loading, "Nonshared DATA segment required", then if
fails to open.  Anyone have experience with this?
Watson
flysrv10(at)gmail.com
PostPosted: Wed Nov 08, 2017 5:54 am    Post subject: Need latest Navworx UAT Console Reply with quote
Does anyone know if AMCO applies to Avidyne ID-540?
Thanks.
On Nov 2, 2017, at 9:38 AM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>Sent: Thursday, November 2, 2017 11:01:53 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Need latest Navworx UAT Console
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help.I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this?A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade).Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks.(I'll be posting on the VAF board as well)Bill "wired up G430w to the deadend box with all appendages crossed" Watson---This email has been checked for viruses by Avast antivirus software.https://www.avast.com/antivirus===========Email Forum --List">http://www.matronics.com/Navigator?RV10-List===========p; - MATRONICS WEB FORUMS -ums.matronics.com===========p; - NEW MATRONICS LIST WIKI -matronics.com===========p; - List Contribution Web Site -p;   -Matt Dralle, List Admin.http://www.matronics.com/contribution===========
recapen(at)earthlink.net
PostPosted: Wed Nov 08, 2017 6:32 am    Post subject: Need latest Navworx UAT Console Reply with quote
Rob,
The three AMOCS that have been approved are all for Garmin products.
That having been said, the most recent responses from the FAA indicate that they may be open to approving other data sources that output the "ADS-B OUT+" protocol as it contains the necessary data elements required for position reporting. In my updated AMOC, they specifically reference the ADS-B OUT+ protocol. If the Avidyne outputs it, you should be able to get approval...
I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want...
Ralph
PostPosted: Wed Nov 08, 2017 6:57 am    Post subject: Need latest Navworx UAT Console Reply with quote
Ralph, thanks for the quick reply. Please send me the package you provided to the FAA. I spoke to Avidyne and they researching it on their end. I will forward your email (if OK with you) to Avidyne and a copy of my proposal to FAA so they also remain in the loop.
Thanks again
Rob.
[quote] On Nov 8, 2017, at 7:31 AM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
Rob,
Ralph
rleffler
PostPosted: Wed Nov 08, 2017 7:06 am    Post subject: Need latest Navworx UAT Console Reply with quote
The avidyne does indeed support adsb+
I can assist with writing the AMOC. It will literally take 5-10 minutes to create the doc to send to the FAA
Email me if you want to go down that path.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Ralph E. Capen <recapen(at)earthlink.net>
Sent: Wednesday, November 8, 2017 9:31:07 AM
Subject: Re: Need latest Navworx UAT Console
--> RV10-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Rob,
Ralph
Bob Leffler
N410BL - Phase I
PostPosted: Wed Nov 08, 2017 8:04 am    Post subject: Need latest Navworx UAT Console Reply with quote
Thanks Bob. Yes ...please, please. What do you need from me?
On Nov 8, 2017, at 8:05 AM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
[quote] The avidyne does indeed support adsb+
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)>
--> RV10-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Rob,
Ralph
rleffler
PostPosted: Wed Nov 08, 2017 1:54 pm    Post subject: Need latest Navworx UAT Console Reply with quote
Wire the Avidyne to the ads600-b using the adsb+ protocol.
I don’t recall if there is an Avidyne example in the Navworx manual.
Use the gtn650/gns430w as an example.  The gps pins will be different, but the NavWorxs side will be the same.
Disconnect the internal gps antenna
Change the Navworx configuration to use the external gps
Validate that you have three green status indicators
Fly and get a copy of the public performance report from the FAA.
If there is an Avidyne schematic in the Navworx manual, we can cut and paste that, if not you’ll have to create an installation schematic. Again, use the Garmin schematics as an example.
Then let me know. It’s a simple cut and paste job using my application as a template.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Rob Kermanj <flysrv10(at)gmail.com>
Sent: Wednesday, November 8, 2017 11:02:27 AM
Get Outlook for iOS
Rob,
Ralph
Bob Leffler
N410BL - Phase I
PostPosted: Wed Nov 08, 2017 3:54 pm    Post subject: Need latest Navworx UAT Console Reply with quote
Thanks Bob. Will do. Will let you how it turns out.
[quote] On Nov 8, 2017, at 2:52 PM, Bob Leffler <bob(at)thelefflers.com> wrote:
Get Outlook for iOS
> Get Outlook for iOS
> Rob,
