kenryan
Posted: Thu Nov 02, 2017 5:49 pm Post subject: copper lugs |
Is it acceptable to use non-plated copper lugs on the 4AWG cables in my starting circuit?
Ken Ryan
Anchorage, Alaska
ceengland7(at)gmail.com Guest
Posted: Fri Nov 03, 2017 9:51 am Post subject: copper lugs |
At 08:46 PM 11/2/2017, you wrote:
Quote: | Is it acceptable to use non-plated copper lugs on the 4AWG cables in my starting circuit?
Ken Ryan
Anchorage, Alaska |
Sure. Recall that we strive for 'gas tight'
connections between the current carrying
components of a power pathway.
Gas-tightness minimizes electrical resistance
in the metallic interfaces, excludes moisture
and oxygen that will degrade the joint over
time. Whether or not surfaces outside the joint
are exposed to the effects of corrosion will
have only cosmetic effects on the assembly.
kenryan
Posted: Fri Nov 03, 2017 10:12 am Post subject: copper lugs |
Thanks. Is it really a good idea to spray connections with something like CorrosionX? If so, would it matter if the parts are sprayed before or after assembly?
On Fri, Nov 3, 2017 at 9:50 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Ken Ryan
Anchorage, Alaska |
Posted: Fri Nov 03, 2017 10:46 am Post subject: copper lugs |
At 01:10 PM 11/3/2017, you wrote:
Quote: | Thanks. Is it really a good idea to spray connections with something like CorrosionX? If so, would it matter if the parts are sprayed before or after assembly? |
Any material designed for and effective for
corrosion control wouldn't hurt. Spraying
before assembly probably wouldn't make
much difference. Recall that 'gas tightness'
goes hand-in-hand with physical deformation
of the metals that make up the joint. Deformation
forces for copper alloys will be measured in
tens of thousands of pounds per square inch.
The compression strength of just about
anything you spray on is immeasurably small.
It simply extrudes out of the contact area
as the make-up forces are applied.
