Wanted: Garmin 496
Albert Gardner
PostPosted: Thu Nov 09, 2017 11:42 pm    Post subject: Wanted: Garmin 496 Reply with quote
My Garmin 496 has died. The simplest solution is for me to simply replace it and avoid having to make other changes to incorporate a different source for GPS data. If anyone has a used unit (in good working order) I'm in the market for it. Don't need any accessories just a 496 with a battery.
Albert Gardner
RV-10 N991RV
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Paul Grimstad
PostPosted: Fri Nov 10, 2017 5:24 am    Post subject: Wanted: Garmin 496 Reply with quote
Hi Albert,
I have 2 496's. I owned one when I decided to build an RV12 which at that time came with one as standard equipment. I will dig around and find it but glad to sell it if you can put it to good use.
Paul Grimstad,
controlapproach
Send a personal email to paul(at)controlapproach.com
<![endif]--> <![endif]-->-------- Original message --------
Date: 11/9/17 11:40 PM (GMT-08:00)
Subject: RV10-List: Wanted: Garmin 496
Albert Gardner
RV-10 N991RV
Yuma, AZ
