Elevator Pushrod Priming?
s51flyer(at)wi.rr.com
PostPosted: Sun Nov 19, 2017 5:50 pm    Post subject: Elevator Pushrod Priming? Reply with quote
Has anyone primed the inside of their elevator pushrod per Van’s recommendation? If so, any quick and easy methods anyone’s discovered? I actually can’t imagine why this is a recommendation unless you live in a salt water climate.
Thanks in advance..
Bob O.
wgreenley
PostPosted: Sun Nov 19, 2017 6:39 pm    Post subject: Elevator Pushrod Priming? Reply with quote
I did. Using a string I pulled some pads back and forth through to scuff, did the same with some rags to clean, then soaked a rag with primer and pulled it through a couple of times.
On Sun, Nov 19, 2017 at 8:49 PM, Bob Orre <s51flyer(at)wi.rr.com (s51flyer(at)wi.rr.com)> wrote:
Thanks in advance..
Bob O.
Dave Saylor
PostPosted: Sun Nov 19, 2017 8:18 pm    Post subject: Elevator Pushrod Priming? Reply with quote
I primed mine per the instructions.  I don't think it's so much "salt water climate" as much as that no one is ever gonna look in there ever again.  And if it somehow did fail, it would be really bad.  So it should be as reliable as possible.
--Dave
On Sun, Nov 19, 2017 at 5:49 PM, Bob Orre <s51flyer(at)wi.rr.com (s51flyer(at)wi.rr.com)> wrote:
Thanks in advance..
Bob O.
--Dave
KWVI
Kellym
PostPosted: Sun Nov 19, 2017 8:44 pm    Post subject: Elevator Pushrod Priming? Reply with quote
Keep in mind that the parts for the pushrod are not Alclad, and thus do
not have the corrosion resistance of the exterior skins. I wouldn't be
surprised if the tube and end caps are different Al alloys.
Van's limits primer recommendations to a very small portion of the kit,
to just those parts that have some risk of corrosion in damp air.
--Dave
unless you live in a salt water climate.____
__ __
Thanks in advance..____
__ __
Bob O.____
Kelly McMullen
KCHD
Bob Turner
PostPosted: Sun Nov 19, 2017 8:51 pm    Post subject: Re: Elevator Pushrod Priming? Reply with quote
--Dave
u]
+1
Same here. After primer had cured, just before inserting rod ends, I also sprayed LPS-2 in there, just for added measure.
Bob Turner
RV-10 QB
philperry9
PostPosted: Mon Nov 20, 2017 4:36 am    Post subject: Elevator Pushrod Priming? Reply with quote
Yep. Capped off one end and filled the tube with acid etch. Dumped it. Rinsed it. Allowed to dry.
Then recalled it. mixed about a cup of primer, poured it in, and rolled the tube around.
Looking inside with a flashlight, you can see where primer is and isn’t. Kept moving it around until it was all coated.
Pretty easy and nothing to fret.
Phil
On Nov 19, 2017, at 7:49 PM, Bob Orre <s51flyer(at)wi.rr.com (s51flyer(at)wi.rr.com)> wrote:
<![endif]--> <![endif]-->
Thanks in advance..
Bob O.
Kellym
PostPosted: Mon Nov 20, 2017 5:35 am    Post subject: Elevator Pushrod Priming? Reply with quote
I would argue against using acid etch/alodine in any area that you can't
access afterwards. I think the risk of not fully removing the acid
exceeds any risk of poor bonding of the paint. The area will never be
subject to any abrasion or scratching that tests paint adhesion.
The primer itself contains sacrificial material to react with any
oxidizing moisture. Of course I don't base in a corrosive atmosphere of
coastal areas, so I'm certainly biased. If we aren't careful, we could
re-ignite primer wars. Wink)
the tube around.
Phil
Kelly McMullen
KCHD
philperry9
PostPosted: Mon Nov 20, 2017 6:04 am    Post subject: Elevator Pushrod Priming? Reply with quote
Fair enough.  I just flushed it and flushed it and flushed it.
Thinking about it more, I even alodined the thing too.    I had a couple of 6-8 ft sections of PVC pipe.  One end was opened up, the other had a fitting where I mounted a hose bibb.   I could fill one pvc tube with acid etch.  The other with alodine.   Then I'd drop the long pieces inside the pvc tube.   When done, I'd open the hose bibb and recapture each solution back in it's original container.  Worked pretty well and I think they're still out in my garage.
On Mon, Nov 20, 2017 at 7:33 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I would argue against using acid etch/alodine in any area that you can't access afterwards. I think the risk of not fully removing the acid exceeds any risk of poor bonding of the paint. The area will never be subject to any abrasion or scratching that tests paint adhesion.
The primer itself contains sacrificial material to react with any oxidizing moisture. Of course I don't base in a corrosive atmosphere of coastal areas, so I'm certainly biased. If we aren't careful, we could re-ignite primer wars. Wink)
Phil
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
PostPosted: Mon Nov 20, 2017 3:08 pm    Post subject: Elevator Pushrod Priming? Reply with quote
Thanks, guys.  Appreciate the feedback.  Good ideas on priming.  Next step, prime the tube….
Bob O.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Monday, November 20, 2017 8:02 AM
Subject: Re: Elevator Pushrod Priming?
Phil
FORUMS -
WIKI -
b Site -
rvdave
PostPosted: Tue Nov 21, 2017 12:18 pm    Post subject: Re: Elevator Pushrod Priming? Reply with quote
I’ve always heard that linseed oil does a good job protecting metal from rusting/corroding when put on properly, that is wiping off the excess . Dousing a rag and pushing and pulling it through the pushrod worked well for me .
Dave Ford
Cadillac, MI
