Instuments Misreading
willydewey
PostPosted: Sun Sep 24, 2017 7:49 am    Post subject: Instuments Misreading Reply with quote
Hi Guys
I had a strange experience this morning while carrying out my power checks.
The EIS was consistently reading low (RPM) compared to the analog instrument. EG when the analog RPM meter showed 4000rpm the EIS only read 2250 rpm ? I know from experience that the anolog meter was more or less correct so whats gone wrong withe the Gulf Coast EIS ?
Any suggestions would be appreciated.
Bill Dewey Question Question
Give a wise man knowledge and he will be yet wiser
tonyvaccarella
PostPosted: Fri Nov 03, 2017 5:10 am    Post subject: Re: Instuments Misreading Reply with quote
Hi Bill,
Thats such a huge RPM variation. My only thought was is one reading engine RPM while the other is reading propeller RPM?
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
pjeffers(at)talktalk.net
PostPosted: Fri Nov 03, 2017 8:39 am    Post subject: Instuments Misreading Reply with quote
Hi Tony, As I am away from home on holiday at present I can't quote details from the EIS manual but I do know that I have in the past experienced somewhat similar corruption of data on my aircraft. In my case it followed a voltage surge within my electrics. The simple fix was to get your manual out and go through the set up procedure . I do recall there being a number of settings associated with RPM readings.
I hope this may help you with your problem. Alternatively phone the manufacturers, I have always found them to be very helpful.
Pete Jeffers
Sent: ‎03/‎11/‎2017 09:57
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Re: Instuments Misreading
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au>
Hi Bill,
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewt - List Contribution p;   &nbs
willydewey
PostPosted: Mon Nov 20, 2017 6:21 am    Post subject: Re: Instuments Misreading Reply with quote
Hi Tony and Pete
I have solved the problem. It was the EIS that had gone out of SYNC
REsetting that has solved the problem
Thanks for your suggestions
Bill Dewey
