Wiring and going on a diet
kearney
PostPosted: Thu Nov 23, 2017 2:45 pm    Post subject: Wiring and going on a diet Reply with quote
Hi
On my build I decided to use CCA (Copper Clad Aluminium) wire from perihelion designs.
Info and specs on it can be found at:
http://www.periheliondesign.com/fatwires.htm
I am quite surprised at how much lighter it is. Apparently it is used by the big guys (ie AirBus etc) due to the weight savings.
Cheers
Les
C-GCWZ Flying
C-GROK Some assembly required
Dave Saylor
PostPosted: Thu Nov 23, 2017 4:01 pm    Post subject: Wiring and going on a diet Reply with quote
I’ve been flying with this wire since 2007.  1700 hours and not a single issue. And yes, significantly lighter.
—Dave
On Thu, Nov 23, 2017 at 2:48 PM kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=475481#475481
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
--Dave
KWVI
Kellym
PostPosted: Thu Nov 23, 2017 5:33 pm    Post subject: Wiring and going on a diet Reply with quote
What do you estimate the weight savings? Perhaps we would do better to
reduce weight of the front seat occupants by say 5 lbs?
—Dave
Hi
perihelion designs.
Cheers
Les
C-GCWZ Flying
FORUMS -
WIKI -
b Site -
Kelly McMullen
KCHD
kearney
PostPosted: Thu Nov 23, 2017 8:40 pm    Post subject: Re: Wiring and going on a diet Reply with quote
Hi Kelly
What a great idea. Go on a diet and also save weight on the battery cable.
Cheers
Les
riveteddragon(at)gmail.co
PostPosted: Thu Nov 23, 2017 8:46 pm    Post subject: Wiring and going on a diet Reply with quote
I thought the aluminum wires were more susceptible to work hardening and cracking than he copper ones.
Steve
On Nov 23, 2017, at 20:40, kearney <kearney(at)shaw.ca> wrote:
Hi Kelly
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=475489#475489
Bob Turner
PostPosted: Thu Nov 23, 2017 9:22 pm    Post subject: Re: Wiring and going on a diet Reply with quote
Like others, I’m curious as to how many pounds were saved.
Also, since this wire is fatter, did you have to oversize any bushings to get the wire(s) thru?
Bob Turner
RV-10 QB
Dave Saylor
PostPosted: Thu Nov 23, 2017 9:56 pm    Post subject: Wiring and going on a diet Reply with quote
If you replace 2AWG with "Super 2 CCA" (what I used) from the battery to the firewall, you save about 2 lbs.
I ran the wire up the right side of the fuse, under the door sill, across the panel structure to my GPU plug in front of the left door.  I did have to accommodate the larger size.  I don't recall any specific adverse issues but like any mod it took more effort.
Perihelion lists specs and discusses work hardening, corrosion, etc.  Like I said, my installation has been trouble free for some time.
--Dave
On Thu, Nov 23, 2017 at 9:22 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=475492#475492
FORUMS -
WIKI -
b Site -
--Dave
KWVI
