RV10 door locks
docclv(at)windstream.net
PostPosted: Tue Nov 21, 2017 5:05 pm    Post subject: RV10 door locks Reply with quote
Guys: I used the extra lock that comes with the kit to make a keyed
lock for the left door. It basically turns the bolt (like the baggage
door) so that the end of the bolt is in line with the top geared slide
bar in the door latch preventing the top geared bar from moving forward
letting the door locking tubes release the door. You can find the
details of how I mounted the lock in Matronics archives or Vans Airforce
archives as I have listed the instructions on each web site. You can
also make a very simple slide in the handle of the right door which
prevents one from pushing the door handle button in from the out side so
the handle can not be turned. This too is in both archives. If you
can't find them, send me a self addressed envelope and I will send you
copies of the instructions and drawings of how to do it. The left door
lock will not mess up the paint if you have it painted already. Carroll
Verhage 1202 Road 12, Geneva, NE 68361 #41087 N123CV
AirMike
PostPosted: Sun Nov 26, 2017 2:21 pm    Post subject: RV10 door locks Reply with quote
I have a very sophisticated door lock on the right (co-pilot) side. I stick a
popsicle stick or tongue depressor in the free space under the aluminum
lock release.
See you OSH '18
Q/B - sold.
Bob Turner
PostPosted: Sun Nov 26, 2017 10:41 pm    Post subject: Re: RV10 door locks Reply with quote
lock release.
I use a small piece of pine for the same purpose. Passengers are less likely to stick it into their mouth. -Smile
Bob Turner
RV-10 QB
