Overhead Air Retro Fit
philperry9
PostPosted: Wed Nov 29, 2017 8:58 am    Post subject: Overhead Air Retro Fit Reply with quote
We are thinking about installing the overhead air panel on an existing RV-10 here on the field.   Has anyone retrofitted the panel on an flying airframe?
I installed mine when my cabin top was off.  But I'm curious what your experience was on the retro fit and issues you encountered?
Phil
aerosport1
PostPosted: Thu Nov 30, 2017 11:36 am    Post subject: Overhead Air Retro Fit Reply with quote
Phil
We have had a couple people over the years install the overhead console after the plane was completed. It is possible
Just awkward because you are working upside down. One person said if was very easy. Never heard from the other
FWIW
Geoff
Geoff Combs
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal, Winchester, Ohio 43110
614-834-5227
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Wednesday, November 29, 2017 11:55 AM
Subject: Overhead Air Retro Fit
Phil
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Tim Olson
PostPosted: Thu Nov 30, 2017 11:56 am    Post subject: Overhead Air Retro Fit Reply with quote
It may be more do-able if you purchase an inverted fuel
and oil system for your RV-10. That way you can
get a helper or two and do it in-flight. If you can
hold it inverted long enough for the quick set
epoxy, it wouldn't be such a tough job.
On 11/30/2017 1:31 PM, Geoff Combs wrote:
Phil
FWIW
Geoff
Geoff Combs
614-834-5227
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry
*Sent:* Wednesday, November 29, 2017 11:55 AM
*To:* rv10-list(at)matronics.com
*Subject:* Overhead Air Retro Fit
airframe?
Phil
philperry9
PostPosted: Thu Nov 30, 2017 12:52 pm    Post subject: Overhead Air Retro Fit Reply with quote
He’s wanting a clear coat over the carbon fiber finish. What’s the process to finish off the carbon surface to get that nice finish?
Phil
> Phil
> FWIW
> Geoff
> Geoff Combs
> 614-834-5227
> *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry
> Phil
kboatright1(at)comcast.ne
PostPosted: Thu Nov 30, 2017 1:10 pm    Post subject: Overhead Air Retro Fit Reply with quote
In my case, it was to use 5 minute epoxy to fill big voids, sand smooth (600 grit), scuff the whole thing with grey scotchbrite, then shoot two coats of finish.
Phil
> Tim
>> Phil
>> FWIW
>> Geoff
>> Geoff Combs
>> 614-834-5227
>> Phil
