kingsnjan(at)westnet.com. Guest
Posted: Tue Jun 20, 2017 1:45 am Post subject: Rotax Oil Tank Drain Plug |
At the next oil change, I would like to replace the drain plug with a quick
action type.
Could some kind soul tell me what size thread is on the oil tank drain plug
please? ie Diameter and pitch.
Kingsley
h&jeuropa
Posted: Tue Jun 20, 2017 4:56 am Post subject: Re: Rotax Oil Tank Drain Plug |
Kingsley,
The IPC shows it as M12x12.
We replaced ours with a quick drain several years ago. They are available from Lockwood. We had problems with the gasket sealing with the plug and the quick drain has solved that problem.
Jim & Heather
Posted: Tue Jun 20, 2017 1:54 pm Post subject: Rotax Oil Tank Drain Plug |
Many thanks Jim.
Yes I noted the M12x12 quoted in the manual but I don't know what 12 x 12 means?? Seems to me that would be one hell of a thread pitch!
I'm wondering if it is a misprint and should be 12 x 1.2?
Looks like I might have to just drain the oil and measure it!
BTW Jim, I have always admired your many contributions to all things Europa . . . . keep up the good work mate!
Best regards
Kingsley
h&jeuropa
ploucandco
Posted: Wed Jun 21, 2017 3:20 am Post subject: Rotax Oil Tank Drain Plug |
More searching shows it is a Saf Air M12175. Available from Aircraft Spruce
at $43.95. So the thread is 12X1.75
http://www.aircraftspruce.com/catalog/eppages/safOilDrainValves.php?clickkey=4298847
Thank you very much once again Jim.
Armed with the info you have so kindly provided, I find I am able to
purchase a similar product here in Oz at a very reasonable price so have now
ordered it.
Much obliged
Kingsley
JohnFrance
Joined: 17 Sep 2014 Posts: 77 Location: Grenoble France
Posted: Wed Jun 21, 2017 6:12 am Post subject: Re: Rotax Oil Tank Drain Plug |
Hello to all, this post made me think I need to fit one of these as well.
A quick search on the Internet yielded this result from Quick Valve in the UK.
Model F107N has a nipple to allow a tube to be fitted and it costs 23.97 GBP plus postage. Mine is on it's way.
http://www.quickvalve.co.uk/f107n_details.htm
_________________ Europa mono Nr 192 |
Jim Kelly
Posted: Wed Jun 21, 2017 6:43 am Post subject: Rotax Oil Tank Drain Plug |
Hi John,
Please keep me posted
Jim Kelly.
G-BWEG Classic Taildragger
On Wed, Jun 21, 2017 at 3:12 PM, JohnFrance <77alembert(at)gmail.com (77alembert(at)gmail.com)> wrote:
Quote: | --> Europa-List message posted by: "JohnFrance" <77alembert(at)gmail.com (77alembert(at)gmail.com)>
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=470324#470324
pa-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Europa-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
_________________ Jim GBWEG |
Posted: Wed Jun 21, 2017 10:43 pm Post subject: Rotax Oil Tank Drain Plug |
John,
Your wrote . . . . .
The product at this link is exactly the same product as what I have ordered over/down here. Only difference is the part number being EZ-107. The hose nipple is extra.
Cheers
Kingsley
JohnFrance
Posted: Mon Dec 04, 2017 1:46 am Post subject: Re: Rotax Oil Tank Drain Plug |
Hello Jim and others who might be interested.
Just to confirm, the drain works well. I drilled a 1.5 mm hole in the casing where the circlip washer goes to allow wire locking in position.
Cheers
[quote="Jim Kelly"]Hi John,
Jim Kelly.
Europa mono Nr 192
pjeffers(at)talktalk.net Guest
Posted: Mon Dec 04, 2017 2:08 am Post subject: Rotax Oil Tank Drain Plug |
Hi,
I feel it necessary to mention that in the UK under LAA rules a mod approval
will probably be required before fitting this item. I think the device may
indeed be a good idea but you cannot just fit it without approval.
Pete Jeffers (LAA Inspector for The Europa Club)
PS Rules applicable outside the UK probably differ
