Posted: Thu Dec 14, 2017 9:49 am Post subject: Control slop |
For the assembled wisdom
I have a minor amount of slop in my controls from the tufnol bearings at front and back of the cockpit module.  I don't notice it in flight but it's an imperfection and l guess we all know how that feels. This is derived either from build or some kind of drying out/shrinkage over the considerable lapse between assembling flying controls and flight.
My thoughts were to drill a hole in the top of the tufnol bearing into which I could inject grease - maybe damping grease.
Anyone got any other ideas that don't include major surgery?
Will
Duncan McFadyean
Posted: Thu Dec 14, 2017 10:06 am Post subject: Control slop |
Will,
You don't say whether radial or axial 'slop'.
Greasing the dried out bearings usually causes the Tufnol to expand in a direction perpendicular to the plane of the fabric, which would remove some axial slop but can cause the bearing to go tight/sticky.
I don't know how you would remove radial slop; grease would be quickly displaced from the imperfect bearing contact of this item.
Duncan McF
Quote: | ----Original Message----
Date: 14/12/2017 17:49
Subj: Control slop
Will
Posted: Thu Dec 14, 2017 10:45 am Post subject: Control slop |
Mmm thanks....
The slop is a little of both...I though about a shim of the same phenolic material like a large washer split in half but as you say about the grease option, this would probably work for the axial movement not the radial slop.
Will
On Dec 14, 2017 13:09, "ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)" <ami-mcfadyean(at)talktalk.net (ami-mcfadyean(at)talktalk.net)> wrote: Quote: | Will,
Duncan McF
From: wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)
To: <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subj: Control slop
Will
budyerly(at)msn.com Guest
Posted: Fri Dec 15, 2017 1:35 pm Post subject: Control slop |
If it isn't broke, don't fix it. A small bit of looseness up to .032" is not going to hurt a thing. Once it gets to .032 you can shim it a bit to feel better.
Bud Yerly,
Custom Flight Creations, Inc.
Sent from my Verizon Wireless 4G LTE DROID
On Dec 14, 2017 1:48 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Will
Duncan McF
Subj: Europa-List: Control slop
Will
rampil
Posted: Fri Dec 15, 2017 2:43 pm Post subject: Re: Control slop |
The Enemy of Good is Better!
Posted: Fri Dec 15, 2017 5:23 pm Post subject: Control slop |
Hahaha....
Thanks for your adjustment to Fred the great.
And thanks to everyone....I will follow Bud's advice and leave well alone...... for now.
Will
On Dec 15, 2017 17:46, "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote: Quote: | --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=476424#476424
FORUMS -
WIKI -
b Site -
     -Matt Dralle, List Admin.
