fuel system CJ-6
cjpilot710(at)aol.com
PostPosted: Sun Jan 07, 2018 1:21 pm    Post subject: fuel system CJ-6 Reply with quote
Troops,
I need a diagram of a CJ-6's fuel system. Not the ordinary one but the one that came with Gill Gruterious bladder tank mod. In it was the set up for being able to select which tank to feed from. It used the tank vents by cutting off the vent of the tank that you did not want to feed from. After all these years I want to make this change.
Right now I'm working on my fuel system because of a very small seep leaking from my right fuel tank. I have the tank out of the wing and have found a 1/16 crack in the front, inboard side of the tank, about 3" from the front.  Trying to decide how to patch it. Looking into a number of products that I can do my self without having to send the tank back to the manufacture and a big expense. Suggestion?
I thought that since I had the system apart I'd put in the mod.
Jim "Pappy" Goolsby
Off2wildblue
PostPosted: Wed Nov 21, 2018 9:32 pm    Post subject: Re: fuel system CJ-6 Reply with quote
Did you ever get any information about this topic? My new CJ has the same system and I can really use a diagram as well.
SAM
