Air inlets manifold o rings
graeme bird
PostPosted: Sun Jan 14, 2018 11:17 pm    Post subject: Air inlets manifold o rings Reply with quote
Thanks for all the help on water pipe clips. In the process of removing the pipes I removed the air inlet manifolds. The o rings looked pretty flattened and I am wondering whether I should replace them or use some small amount of liquid gasket from a tube? I am aware you don't want a leak here and sucking in air.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
Remi Guerner
PostPosted: Mon Jan 15, 2018 1:25 am    Post subject: Re: Air inlets manifold o rings Reply with quote
Graeme,
Good practice is to replace any o-ring after removal, especially when they are used in high temperature conditions. It is a cheap insurance. Do not mess with sealing stuff which could be sucked into the engine!
regards
Remi
