LAA Airworthiness Alert. AIL December 2017 All Europas
brian.davies44(at)gmail.c
PostPosted: Tue Jan 23, 2018 6:18 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Update on the LAA Standard Mod for UK owners to replace the XS filler elbow with an aluminium one. The Mod is now prepared and is awaiting final signature. It will approve the use of Tim's 53 degree elbow and also a 60 degree elbow that is available ex-stock from http://www.autosiliconehoses.com Look under Custom Alloy Hose Pipe Joiner. They cost Uk£12 plus postage. Tim's elbow is a better fit in most installations but if you are in a hurry and cannot wait for the next production run you have the option of the 60 degree elbow available now.
The Standard Mod requires the use of fuel proof connecting hoses ( Samco Profuel or equivalent) and this is available in short lengths from www.merlinmotorsport.co.uk currently on 22 days back order, currently UK£ 11.24 plus VAT and postage.
That should give you sufficient information to order parts with confidence that the Mod will be available by the time you have the parts.
Brian
