rowlandcarson(at)gmail.co Guest
Posted: Mon Aug 13, 2012 12:30 pm Post subject: rotax integrated alternator warning light |
I've been trying to find out the purpose of the alternator warning light in the Rotax engine circuit diagram. Originally I had assumed it would light up if the alternator died and stopped producing useful output. Then I thought - where, in that circumstance, would the warning light get its power from?
I can't find any description of its function in the Rotax engine manuals. Does anyone know what it's for and when one should expect it to light up?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
BobD
Joined: 05 Jan 2016 Posts: 110 Location: Sheffield UK
Posted: Tue Jan 23, 2018 10:35 am Post subject: Re: rotax integrated alternator warning light |
Roland, did you ever get an answer to this question ?
I have the standard Alternator Fail lamp wired in as shown in the manual. I have yet to see it lit. Should it perform in the same way as on a car, i.e. should it light when the master switch is turned on, then extinguish once the engine is running, and the Alternator producing power ?
If not, how can I test it is working ?
_________________ Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 |
dpark748(at)me.com Guest
Posted: Tue Jan 23, 2018 11:24 am Post subject: rotax integrated alternator warning light |
Yes with engine running and alternator switched on?
Dave Park
Bob Dawson
http://forums.matronics.com/viewtopic.php?p=477512#477512
BobD
Posted: Wed Jan 24, 2018 4:05 pm Post subject: Re: rotax integrated alternator warning light |
I discovered the warning light I have used is polarity sensitive, so when I swapped the wires, the light did indeed come on with the Master Switch. I'll take it on faith at the moment that it extinguishes once the engine is running, as I didn't start her up today.
budyerly(at)msn.com Guest
Posted: Wed Jan 24, 2018 7:06 pm Post subject: rotax integrated alternator warning light |
It is interesting that what was old is new again.
In a 1998 discussion the voltage warning bulb is a grain of wheat bulb or 3W/12V standard incandescent bulb. It should not be a LED in a Ducati Regulator.
Note the older Rotax installation manuals. The new 912 install manual is very poor in describing the electrical installation for some reason. The build manual Chapter 25 indicates the same to use a 3W bulb.
Long answer Ducati Only:
Battery voltage at B+ is supplied to the regulator and in the circuit the L or light is connected to the C or control (Bus Voltage) and is to be within .2 Volts of battery. When the regulator C and R, and B+ are powered by the battery the light is illuminated because the voltage output of the generator side(also the L) is at Zero volts (basically ground).
When the engine is started the Alternator supplies AC voltage to the Regulator via GG and converts it to DC voltage. As the voltage output rises, the L circuit is powered by the generated output of the Alternator and as the L and C voltage near equal voltage, the lamp then goes out indicating the alternator is generating charging voltage.
In the event the alternator stator fails L goes to ground or less than battery voltage, the light illuminates, warning the pilot of the output failure as C voltage is greater than L voltage. Unfortunately if the Regulator fails internally, the light will not work leaving your first clue the regulator failed is a low voltage warning or dead battery.
Hence the term idiot light.
If you have a LED installed as the alternator warning light, you have a problem. The LED takes 1.2 volts to energize and of course only works one way as you found out. I have seen them work or not work as this is a temperamental current circuit.
I won’t argue the point. With a Ducati, just put in a grain of wheat bulb and be done with it. Do not put in a circuit breaker or fuse in the warning light circuit as the 3Watt bulb is the circuit protection. It will blow before the wire will fry. 20 or 22 gauge wire is all that is needed to wire this circuit, as no fuse is really necessary.
Should you decide on a Schicke GR6 voltage regulator, that solid state unit does require an LED and a .5 amp fuse in the warning circuit as it is a totally different design.
The LAA requires a warning light, however in other parts of the world if one has a volt meter or low voltage warning system, a warning light is not required. I am the department of redundant redundancy, I have an idiot light, low voltage warning on the EFIS and a volt/amp meter. Trouble shooting is a breeze.
Bud Yerly
Custom Flight Creations, Inc.
Sent from Mail for Windows 10
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of BobD <rjd(at)bobdawson.plus.com>
Sent: Wednesday, January 24, 2018 7:05:57 PM
Subject: Re: rotax integrated alternator warning light
--> Europa-List message posted by: "BobD" <rjd(at)bobdawson.plus.com>
Bob Dawson
https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D477554%23477554&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=KEs5dQq1Fj6Q2ZzUbklKcshD8lQk3vy6hBdl3ozZxpw%3D&reserved=0
st Email Forum -
ook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=HqRl0WraM%2BHU4vI1Z4nE0iw0SSUHttqpqa5LFoiQrTk%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=HqRl0WraM%2BHU4vI1Z4nE0iw0SSUHttqpqa5LFoiQrTk%3D&reserved=0
p; - MATRONICS WEB FORUMS -
ook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=IUO12J4q%2FzVTSmXyBfxChKBrrP5rB1bRwCIaoeLWYxU%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=IUO12J4q%2FzVTSmXyBfxChKBrrP5rB1bRwCIaoeLWYxU%3D&reserved=0
p; - NEW MATRONICS LIST WIKI -
ook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=OWCdAu5qs5eZ2cMvAGhbSD4YmCUaDbyyiU4uMntMCGY%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=OWCdAu5qs5eZ2cMvAGhbSD4YmCUaDbyyiU4uMntMCGY%3D&reserved=0
p; - List Contribution Web Site -
p; -Matt Dralle, List Admin.
ook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=KGu0gj4zZnnrcKzXrl6FhV6OVVjgwSynhIy7msX9Qcs%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7Cb018da16059849c1e06c08d56387f03a%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636524357864141437&sdata=KGu0gj4zZnnrcKzXrl6FhV6OVVjgwSynhIy7msX9Qcs%3D&reserved=0
