LAA Airworthiness Alert. AIL December 2017 All Europas
dpark748(at)me.com
PostPosted: Tue Jan 23, 2018 10:10 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Is there any accommodation for owners who have previously had an alloy angle welded up and have been operating safely for years?
Dave Park G-LDVO
[quote] On 23 Jan 2018, at 14:18, Brian Davies <brian.davies44(at)gmail.com> wrote:
Update on the LAA Standard Mod for UK owners to replace the XS filler elbow with an aluminium one. The Mod is now prepared and is awaiting final signature. It will approve the use of Tim's 53 degree elbow and also a 60 degree elbow that is available ex-stock from http://www.autosiliconehoses.com Look under Custom Alloy Hose Pipe Joiner. They cost Uk£12 plus postage. Tim's elbow is a better fit in most installations but if you are in a hurry and cannot wait for the next production run you have the option of the 60 degree elbow available now.
The Standard Mod requires the use of fuel proof connecting hoses ( Samco Profuel or equivalent) and this is available in short lengths from www.merlinmotorsport.co.uk currently on 22 days back order, currently UK£ 11.24 plus VAT and postage.
That should give you sufficient information to order parts with confidence that the Mod will be available by the time you have the parts.
Brian
PostPosted: Wed Jan 24, 2018 1:39 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Hi Dave,
It is not possible to make the LAA Standard mod fit every solution out there. My advice would be to apply for a prototype mod specifically for your aircraft. That is what I did for my aircraft as a precursor to requesting the standard mod.
Brian
dpark748(at)me.com
PostPosted: Wed Jan 24, 2018 3:31 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Thanks Brian,
Will do
Dave Park G-LDVO
[quote] On 24 Jan 2018, at 09:37, Brian Davies <brian.davies44(at)gmail.com> wrote:
Hi Dave,
Brian
