Spay Latex on Aluminum
Goto page Previous  1, 2
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
steven.d.dortch(at)gmail.
PostPosted: Tue Jan 30, 2018 5:18 pm    Post subject: Spay Latex on Aluminum Reply with quote
no need to point out making sure the aluminium ( I spelled it the British way) needs to be clean and dry. Otherwise, easy to use.
My personal problem is saying "That looks very good and smooth! Imagine what one more coat will do!" and ending up with a run.
Blue Skies,
Steve D
On Tue, Jan 30, 2018 at 7:11 PM, Jim Boyer <boyerjrb(at)comcast.net (boyerjrb(at)comcast.net)> wrote:
Thank you Steve; I got 3 cans today and will be using it tomorrow. Jim
On January 29, 2018 at 7:50 AM Steven Dortch <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
Rust-Oleum, in the aviation section of Lowes.
On Jan 29, 2018 9:28 AM, "Jim Boyer" <boyerjrb(at)comcast.net (boyerjrb(at)comcast.net)> wrote:
Steve where did you get the self etching primer and what brand. Thanks, Jim B.
On January 29, 2018 at 6:10 AM Steven Dortch <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
I would also think that latex on metal would not handle scuffing and such. If it is not in an area that sees much wear, latex seems fine.
I my self mostly used rattlecan spray paint on metal using a self etching primer.
On Mon, Jan 29, 2018 at 7:51 AM, Michael Perez <speedbrake(at)sbcglobal.net (speedbrake(at)sbcglobal.net)> wrote:
Hello Rick. Yes, I remember your test piece on a post..hard to believe you still have it there!
Latex not holding up well on aluminum and fuel is good to know; thanks!  On the aluminum parts covered with latex, did you top coat those areas with any type of clear? (polyurethane or ...?)
Blue Skies,
Steve D
Blue Skies,
Steve D
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Catdesigns
PostPosted: Tue Jan 30, 2018 6:25 pm    Post subject: Spay Latex on Aluminum Reply with quote
Jim
Have been able to get back to work on the Piet since the fires?
Chris
Try the top-rated email app
On Tue, Jan 30, 2018 at 5:12 PM, Jim Boyer
On January 29, 2018 at 7:50 AM Steven Dortch <steven.d.dortch(at)gmail.com> wrote:Rust-Oleum, in the aviation section of Lowes.
On January 29, 2018 at 6:10 AM Steven Dortch <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:I would also think that latex on metal would not handle scuffing and such. If it is not in an area that sees much wear, latex seems fine.
Hello Rick. Yes, I remember your test piece on a post..hard to believe you still have it there!Latex not holding up well on aluminum and fuel is good to know; thanks! On the aluminum parts covered with latex, did you top coat those areas with any type of clear? (polyurethane or ..?)
-- Blue Skies,
Steve D
Chris
Sacramento, CA
WestCoastPiet.com
PostPosted: Wed Jan 31, 2018 8:26 am    Post subject: Spay Latex on Aluminum Reply with quote
I am familiar with runs; painted the fin and rudder Kelly Green; very pretty but it was so dark I thought boy that is nice. Next day noticed a huge run at the lower corner; so after much sanding and repainting its okay. Older eyes don't see things as well any more.
On January 30, 2018 at 5:18 PM Steven Dortch <steven.d.dortch(at)gmail.com> wrote:
Blue Skies,
Steve D
Blue Skies,
Steve D
Blue Skies,
Steve D
PostPosted: Wed Jan 31, 2018 8:32 am    Post subject: Spay Latex on Aluminum Reply with quote
Yep I have now Chris. I am starting to paint the aluminium cowlings and metal parts now. Fuselage and tail surfaces are all done, painted, assembled and cables adjusted. Wings have primer on them (done just before the fires) but still need more. Now its too cold so may be the first spring task. Some sort of engine cowling has to be done yet..
On January 30, 2018 at 6:24 PM Chris Tracy <catdesigns(at)att.net> wrote:
Jim
Chris
Hello Rick. Yes, I remember your test piece on a post..hard to believe you still have it there!Latex not holding up well on aluminum and fuel is good to know; thanks!  On the aluminum parts covered with latex, did you top coat those areas with any type of clear? (polyurethane or ...?)
-- Blue Skies,
Steve D
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 2 of 2
