BTLYak
Posted: Thu Feb 01, 2018 8:36 am Post subject: Exhaust Spanner Tool |
Anyone have an exhaust spanner tool available?
Prefer something that won't break.
_________________ "Battle Yak" |
byronmfox(at)gmail.com Guest
Posted: Thu Feb 01, 2018 8:49 am Post subject: Exhaust Spanner Tool |
Doug Sapp has these pin wrenches
Blitz Fox415-307-2405
On Feb 1, 2018, at 8:36 AM, BTLYak <btlyak1(at)gmail.com (btlyak1(at)gmail.com)> wrote:
Quote: | --> Yak-List message posted by: "BTLYak" <btlyak1(at)gmail.com (btlyak1(at)gmail.com)>
"Battle Yak"
http://forums.matronics.com/viewtopic.php?p=477744#477744
<================================================http://www.matronics.com/Navigator?==============================================================================bsp; - NEW MATRONICS LIST WIK===================================================http://www.matronics.com/contr============================================
dougsappllc(at)gmail.com Guest
Posted: Thu Feb 01, 2018 8:56 am Post subject: Exhaust Spanner Tool |
We are doing a small run of 50 of the pin wrenches now. Stronger pin (actually a roller bearing), pin is replaceable. it is a all round better tool than we have been able to offer in the past.Will have them in stock in about 30 days.
Doug
On Thu, Feb 1, 2018 at 8:36 AM, BTLYak <btlyak1(at)gmail.com (btlyak1(at)gmail.com)> wrote:
"Battle Yak"
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Clouddog
Posted: Thu Feb 01, 2018 10:56 am Post subject: Exhaust Spanner Tool |
Good Exhaust Spanners are hard to come by. Since you say, one that won't break, here are three suggestions. 1. I use to break and need the pin all the time. What I discovered is the radius of the wrench is not always a perfect fit on our gland nuts. I noticed that there were high points on the radius thus getting a rocking effect and only putting pressure on the high point. Probably not good for the gland nut. When you a wrench look at that. I ground the radius to get a 100 percent surface to surface contact. Problem solved!
2. Go on eBay. There is a guy that sells an excellent heavy duty, big faced longer radius wrench that is absolutely. OUTSTANDING! He also has other CJ and YAK stuff. Super to work with.
3. I had several gland wrenches over the years with broken pins. I took them and had them modified where I can replace the pins if necessary. Of course, this was before I learned to grind out the radius for the perfect fit and then I discovered the guy on eBay. Contact me off list and I'll send you his contact info when I get home.
Greg
On Feb 1, 2018 10:40 AM, "BTLYak" <btlyak1(at)gmail.com (btlyak1(at)gmail.com)> wrote: Quote: | --> Yak-List message posted by: "BTLYak" <btlyak1(at)gmail.com (btlyak1(at)gmail.com)>
"Battle Yak"
FORUMS -
WIKI -
b Site -
Lancer
Joined: 21 Apr 2016 Posts: 30 Location: Cairns, Australia
