How does floor of light color wood maintain?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> AnPMech-List
fengqingxue
PostPosted: Sun Jan 15, 2017 7:19 pm    Post subject: How does floor of light color wood maintain? Reply with quote
A lot of families choose wooden floor board in decorate now, big subsequently and come maintain the problem makes injury of a lot of people showed head, especially floor of light color wood, if you also are this affliction, follow quickly small make up what see floor of light color wood together to maintain skill.
Floor of light color wood maintains skill
1, face of local floor board is stained with smear to should keep clear of in time carelessly, if oil stains can use dishcloth or mop to dip in Wen Shui or a few washing powder is wiped, usable also and neuter suds adds spirit of a few catharsis to swab. If smear is serious, use this law to disable, usable and excellent sand paper or steel wire ball are wiped gently. If be medicaments, beverage or painty smear, must be in smear did not try to keep clear of before infiltration woodiness surface, cleared method uses dip to dip in the soft cloth of furniture polish is wiped. If still disable, must dip in with steel wire ball furniture polish is brushed. The surface of the ply that be like the ground is burned by butt caustic, with dip the soft cloth of furniture polish wipes recoverable brightness forcibly. If ink is infected with, answer to be wiped in time with dip candle soft cloth, if disable, but ball of reoccupy steel wire dips in furniture polish is wiped.
2, retain a floor board dry, clean, wringing mop pulls the land or cannot swab with buck, suds with water, lest destroy paint film of the brightness of paint, attaint. If encounter,have ash or use twist dry wet mop to wipe. Every months (or two months) hit candle (before waxing, mix lunt smear wipe up) .
3, if central heating is slack or the ground has water floodwater on low-lying land, must seasonable wipe up, cannot let the sun explode bask in or use hot plate directly roast, lest dry too fast, floor craze.
4, do not live for a long time person, avoid by all means uses plastic cloth or newspaper shell, one long paint film can send time sticky, lose luster, at the same time avoid by all means heats up the content such as birdbath, hot rice cooker to be put on floor face directly, applied board or straw mattress are being filled up, lest iron bad paint film.
5, the floor is in use process, if discover individual floor board rises to become warped or fall off, answer to take a floor in time, the shovel goes old glue and grey end, tu Shangxin glue, squeezing ramming; If damaged of paint film of individual floor board or dew are white, can dip in with 400 waterproof abrasive paper suds burnish, next wipe up, wait for after working, have local complementary color, after color works, brush besmear again a lacquer, dry after 24 hours, burnish with 400 waterproof abrasive paper, brush candle to undertake polishing next.
6, the paint floor after laid, reduce the sun to be basked in continuously as far as possible, lest illuminate of paint classics ultraviolet ray is overmuch, shift to an earlier date weather-shack with ageing. Furniture application rubber is placed on the floor or mat of other pliable other people rises, in case score floor lacquer.
Of floor of light color wood maintain still calculate go easily simply, the little skill of above introduction you might as well try, absolutely meeting makes you harvest the effect that expect is less than.
More information:
environmentally friendly wood plastic deck
timber decking in mauritius
diy wpc suppliers in uae
timber deck boards for sale in los angeles
- The Matronics AnPMech-List Email Forum -
http://www.matronics.com/Navigator?AnPMech-List
alisondaewon
PostPosted: Sat Feb 10, 2018 4:53 am    Post subject: Re: How does floor of light color wood maintain? Reply with quote
It depends on your home furniture. Your sofa and appliances seem nice. Dark flooring gives a feel modern and relaxed mood. BestAssignmentService.com I would recommend putting a light color square rug and add some bright color decorative accessories to bring out the difference appeals. Hope my suggestion helps.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> AnPMech-List All times are GMT - 8 Hours
