Ragwing Ultra-Piet
Goto page Previous  1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
oldbird
PostPosted: Tue Nov 07, 2017 8:24 am    Post subject: Ragwing Ultra-Piet Reply with quote
I used West 105/206 epoxy to coat most of the wood parts, no varnish, urethane, boat or otherwise. Helps pre-coating the insides of the parts before glueing them on. You don't need to mask.
Happy landings
Semih
Istanbul - Turkey
On Mon, Nov 6, 2017 at 7:38 PM, Dale Johnson <ddjohn1936(at)gmail.com (ddjohn1936(at)gmail.com)> wrote:
Use Minwax Helmsman  Spar Urethane. It gives good UV protection.
That is what I use.
Dale
Virus-free. www.avast.com [url=#m_2424776244014032181_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
On Sun, Nov 5, 2017 at 6:28 PM, cdlwingnut <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "cdlwingnut" <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)>
I have my tail feathers almost done and am thinking i should varnish them now so they are protected while i continue building, what varnish should i use will the minwax from menards work or is there a brand that works the best?
http://forums.matronics.com/viewtopic.php?p=474451#474451
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
Semih Oksay
- The Matronics Pietenpol-List Email Forum -
 Filesize:  101.68 KB
 Viewed:  3351 Time(s)
 Filesize:  94.64 KB
cdlwingnut
PostPosted: Fri Dec 08, 2017 6:22 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
that looks great oldbird, you are going to have a very nice bird
a little update on my progress still haven't varnished yet but did finish my tail feathers and am now working on attaching the plywood to the fuselage sides. Oh and doing a lot of sanding.
 Filesize:  287.94 KB
 Viewed:  3229 Time(s)
 Filesize:  212.03 KB
 Filesize:  179.57 KB
 Filesize:  197.01 KB
 Filesize:  206.3 KB
 Filesize:  188.01 KB
Ray Krause
PostPosted: Fri Dec 08, 2017 6:45 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Those bricks might make it pretty heavy?!
Ray Krause
SkyScout
Sent from my iPad
http://forums.matronics.com/viewtopic.php?p=476262#476262
http://forums.matronics.com//files/rib_plywood_196.jpg
http://forums.matronics.com//files/plywood_side_one_2_812.jpg
http://forums.matronics.com//files/plywood_side_side_1_140.jpg
http://forums.matronics.com//files/h_stab_gusset_784.jpg
http://forums.matronics.com//files/h_stab_gusset_2_104.jpg
http://forums.matronics.com//files/elevators_102.jpg
cdlwingnut
PostPosted: Fri Jan 12, 2018 6:09 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
started to put the sides of my fuselage together. with a lot of imagination its starting to look a little like an airplane
 Filesize:  204.7 KB
 Viewed:  3068 Time(s)
kipgohio1957(at)gmail.com
PostPosted: Sat Jan 13, 2018 7:15 am    Post subject: Ragwing Ultra-Piet Reply with quote
For a variety of reasons, I am in the process of selling my full-scale Piet project, and am planning on starting on a Ragwing version, so I’ll be interested in following your progress. I will probably make the Heath Parasol version, just because I like the lines of the tail feathers and wings. Roughly half of the Ragwing designs are essentially the same plane with variations on empennage lines, outer wing shape and wing attachment. I will probably build it to register as a LSA so that i don’t have to be excessively concerned about weight (also, my life insurance policy specifically excludes death by ultralight accident, but it’s OK if i die in a certificated, registered aircraft). I only weigh 135 lbs. so a little extra weight in the aircraft for instruments, brakes, etc. is no big deal.
Kip Gardner
http://forums.matronics.com/viewtopic.php?p=477256#477256
http://forums.matronics.com//files/fuse_fit_together_196.jpg
cdlwingnut
PostPosted: Sat Jan 13, 2018 9:33 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Kip
I have the plans for both the Heath and the Ultra-piet
I went with the piet for both the pietenpol look and because i think it looks a little sturdier, there's a little more plywood in it
the heath does look easier to build though,
either way keep in touch i'd love to hear how the build goes and how it flies
cdlwingnut
PostPosted: Wed Jan 17, 2018 5:31 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I removed from the jig and flipped the fuselage over to glue in more members still rechecking to make sure it's square
 Filesize:  296 KB
 Viewed:  3012 Time(s)
 Filesize:  257.51 KB
cdlwingnut
PostPosted: Wed Feb 07, 2018 4:19 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Been working on the fuselage some more
 Filesize:  224.39 KB
 Viewed:  2886 Time(s)
cdlwingnut
PostPosted: Mon Feb 19, 2018 5:14 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I glued the cross bracing in and the gusset strip to the bottom
 Filesize:  253.93 KB
 Viewed:  2813 Time(s)
cdlwingnut
PostPosted: Fri Feb 23, 2018 7:32 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
One year in on my build. So far i have built all 22 of the ribs. The vertical fin and rudder. The horizontal tail feathers. And have the fuselage in the boat stage. Still a ton to do yet but starting to look like something resembling an airplane
 Filesize:  198.42 KB
 Viewed:  2781 Time(s)
 Filesize:  217.95 KB
 Filesize:  278.29 KB
 Filesize:  271.64 KB
PostPosted: Sat Feb 24, 2018 5:14 am    Post subject: Ragwing Ultra-Piet Reply with quote
Curious, since I have decided to give up my ‘big’ Piet project in favor of this approach, what are you thinking of for an engine? Roger Mann is suggesting a full-case (not cut) 1/2 VW, and I think that sounds like a good idea.
Kip Gardner
http://forums.matronics.com/viewtopic.php?p=478219#478219
http://forums.matronics.com//files/20180223_154428_resized_383.jpg
http://forums.matronics.com//files/20180223_154441_resized_124.jpg
http://forums.matronics.com//files/20180223_154446_resized_421.jpg
http://forums.matronics.com//files/20180223_154459_resized_520.jpg
jack(at)textors.com
PostPosted: Sat Feb 24, 2018 6:00 am    Post subject: Ragwing Ultra-Piet Reply with quote
Very nice looking work!
Jack Textor
Sent from my iPad
cdlwingnut
PostPosted: Sat Feb 24, 2018 9:41 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Thank you jack. And im planning on using a rotax 503 for an an engine
cdlwingnut
PostPosted: Wed Feb 28, 2018 6:42 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
The door is cut out. The gas tank test fitted and started working on the seat.
 Filesize:  273.55 KB
 Viewed:  2681 Time(s)
taildrags
PostPosted: Thu Mar 01, 2018 8:21 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
cdlwingnut- what is the fuel capacity of your tank? I'm assuming that it's less than the Part 103 maximum allowable 5 gallons, but can't tell from the photo what the capacity is. And I guess I don't know enough about the Ultra Piet weight & balance, but it seems like having the fuel behind the pilot would put the CG with full fuel quite a bit aft, shifting forward as the fuel burned off.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
PostPosted: Thu Mar 01, 2018 9:52 am    Post subject: Ragwing Ultra-Piet Reply with quote
I would have concerns about that location.
Oscar Zuniga
Medford, OR
Air Camper NX41CC &quot;Scout&quot;
http://forums.matronics.com/viewtopic.php?p=478331#478331
tkreiner
PostPosted: Thu Mar 01, 2018 12:15 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
In a climb - nose high attitude - the tank might possibly have zero fuel head to the carb.
I'd recommend speaking with an EAA Tech Counselor NOW, not later.
Best luck with your build.
Tom Kreiner
danoliver
PostPosted: Thu Mar 01, 2018 2:53 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
The pace of your progress is absolutely inspirational! Keep us posted and keep following the plans.
 Filesize:  606.11 KB
 Viewed:  2649 Time(s)
Dan O
cdlwingnut
PostPosted: Thu Mar 01, 2018 4:53 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
The fuel tank is 6 gallons this plane will have an N number and be light sport. Im not worried by needing a license or medical i have more than whats needed in both. As far as the location oc the tank it is exactly where the plans have it put.
Today i finished cutting out the seat and floorboard
 Filesize:  222.65 KB
 Viewed:  2636 Time(s)
tkreiner
PostPosted: Thu Mar 01, 2018 6:54 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Maybe y'all ought to verify the correct fuel tank location, as it appears that nothing is in the lower bay - take a look at the plywood thru the cutouts in the side of the fuse.
From my perspective, it appears to be in the bay located in the turtle deck.
That location would make much more sense from a fuel flow standpoint.
Tom Kreiner
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 2 of 5
