Europa-List Digest: 3 Msgs - 02/21/18
tonyrenshaw268(at)gmail.c
PostPosted: Thu Feb 22, 2018 12:04 pm    Post subject: Europa-List Digest: 3 Msgs - 02/21/18 Reply with quote
Hi Graeme,
I have a dedicated static pressure switch valve, panel mounted, purpose built.
I’ll check but I probably got it from Spruce.
TR
On 22 Feb 2018, at 6:34 pm, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-02-21&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-02-21&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Wed 02/21/18: 3
Today's Message Index:
1. 06:17 AM - Alternate static port & Switch (graeme bird)
2. 06:31 AM - Re: Alternate static port & Switch (Alan Burrill)
3. 03:52 PM - Re: Alternate static port & Switch (BobD)
Time: 06:17:21 AM PST US
Subject: Alternate static port & Switch
I put in MOD 2 for my heated pitot tube and one of the points that came back was
that i'd need to be able to select an alternate static port. Has anyone used
a natty panel mount widget/switch for this which connects to 6mm pvc tubing?
Graeme Bird
G-UMPY - Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis
AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on Nexus,
SmartA3
325 hours &amp; 6 years on the Mono, 930 total
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=478172#478172
Time: 06:31:23 AM PST US
Subject: Re: Alternate static port & Switch
I=99ve seen one of these used.
http://www.skydrive.co.uk/proddetail.asp?prod=SOV-125
Alan
Sent from my iPad
ck was that i'd need to be able to select an alternate static port. Has anyo
ne used a natty panel mount widget/switch for this which connects to 6mm pvc
tubing?
> Graeme Bird
xis AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on N
exus, SmartA3
> g(at)gdbmk.co.uk
Time: 03:52:20 PM PST US
Graeme, I used one of these, panel mounted, to give me an alternate static port.
It took a while to arrive, but I think you can get them quicker from the UK
for about 25
https://www.ebay.co.uk/p/Tv-3s-2position-2-Way-Air-Pneumatic-Knob-Control-on-off-Toggle-Valve-Silver-M1l8/1185735205
Bob Dawson
XS TG || 912 ULS || G-NHRJ
http://forums.matronics.com/viewtopic.php?p=478180#478180
