spcialeffects
Posted: Fri Apr 13, 2018 10:12 pm Post subject: Seatbelts |
Does anyone have the specifications of the seatbelts that are supplied by Europa? eg strength,flammability etc
Many thanks Frank
Nigel Graham
Joined: 23 Mar 2017 Posts: 36 Location: Winchester - UK
Posted: Fri Apr 13, 2018 11:59 pm Post subject: Re: Seatbelts |
Frank,
The original seat belts were supplied by a company called "Total Restraint Systems". If you need technical information you could contact them directly at:
http://www.trs-motorsport.com/ (contact numbers and address on their website)
Nigel
Roland
Posted: Sun Apr 15, 2018 11:14 pm Post subject: Re: Seatbelts |
Hi Frank,
FWIW I have mine from Schroth in Germany https://www.schroth.com/en/segments/aviation.html . They've manufactured seat belts for other Europas as well.
Roland
PH-ZTI
XS TG 914
Posted: Mon Apr 16, 2018 12:15 am Post subject: Seatbelts |
I missed the beginning of this thread, but if it is any help I have a set of used but entirely useable seat belts free to a good home. David Joyce, GXSDJ
rampil
Posted: Tue Apr 17, 2018 10:36 am Post subject: Re: Seatbelts |
As the Europa was a fully supplied kit, not a plans-built aircraft,
There are no “specs” as you request for any part
of the aircraft at all except the Rotax specs for engine
fluids. Indeed, engineering specs like flammability requirements
are not a part of any OBAM type aircraft. You might
be looking for what your local jurisdiction might want.
In the US there are no such requirements for
Experimental owner built aircraft, only for
for factory built aircraft.
spcialeffects
Posted: Fri Apr 20, 2018 6:17 am Post subject: Re: Seatbelts |
Thanks very much Nigel.
spcialeffects
Posted: Wed Apr 25, 2018 7:27 am Post subject: Re: Seatbelts |
