Europa-List: Amp fluctuation
duanefamly(at)aol.com
PostPosted: Sun Apr 22, 2018 3:11 pm    Post subject: Europa-List: Amp fluctuation Reply with quote
Have you checked the Dynon website to make sure you have the latest software? If not, I would start there.
Sent from Windows Mail
From: William Daniell (wdaniell.longport(at)gmail.com)
Sent: â€ŽSunday‎, ‎April‎ ‎22‎, ‎2018 ‎7‎:‎34‎ ‎AM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
There is a bit of information on this issue on the web but I wanted to see if there is any further experience/wisdom.
My Dynon ammeter normally shows 8 amps once the battery has finished charging - say after about 30 mins of flight.
However occasionally it just rises through 70 amps until the instrument is covered by a red X.  The solution hitherto has been to cycle the ALT.  This has only happened on the ground until today.  I assumed hithertoo it was a bug in the Dynon system.
Today I have different symptoms  - an increase to 25+ amps and then back down again.   And in flight.  I doubt very much whether the rotax generator can produce 25A!   The Alt has a 25A CB on it as well.
Volts remain stable at 13.4
My Dynon has the factory supplied shunt.
I plan to check the connections first especially with the regulator.
Any other ideas?
Will
