Kellym
Joined: 10 Jan 2006 Posts: 1700 Location: Sun Lakes AZ
Posted: Sat May 05, 2018 4:49 pm Post subject: [SUSPECTED SPAM] Re: Cleveland Wheels - parts breakdown |
It is the correct page. Note that the molded seals are nice, similar to
what Matco uses on the nose wheel. However, be sitting down when you
price those gems. Felt works fine, especially if you are going to
re-pack the bearings every year. You are doing great. Watch your brake
pads. Depending on amount of use, you may very well need to change pads
before your next year is up.
On 5/5/2018 3:10 PM, David Saylor wrote:
Quote: | Here ya go, Phil. I think this is the page you're looking for.
Here's the whole catalog
<http://www.parker.com/parkerimages/Parker.com/Literature/Aircraft%20Wheel%20&%20Brake%20Division/AWB%20Static%20Files%20for%20Literature/AWBPC0001.pdf>.
KCHD |
philperry9
Posted: Sat May 05, 2018 5:09 pm Post subject: [SUSPECTED SPAM] Re: Cleveland Wheels - parts breakdown |
Thanks For reminding me Kelly. I meant to say the pads look really good. But I will watch them at fill-time.
I think the wear is a direct correlation to our runway length. We’ve got 5,500’ on an uncontrolled field, so I can usually ride a mile long wheelie from the touchdown point all the way to the hangar area. Minimal braking here on the home field - most of the time.
Phil
Quote: | On May 5, 2018, at 7:46 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
It is the correct page. Note that the molded seals are nice, similar to what Matco uses on the nose wheel. However, be sitting down when you price those gems. Felt works fine, especially if you are going to re-pack the bearings every year. You are doing great. Watch your brake pads. Depending on amount of use, you may very well need to change pads before your next year is up.
> Here's the whole catalog <http://www.parker.com/parkerimages/Parker.com/Literature/Aircraft%20Wheel%20&%20Brake%20Division/AWB%20Static%20Files%20for%20Literature/AWBPC0001.pdf>.
