Orientation of NAV/VOR antenna compared to COM antenna
cakeykev(at)gmail.com
PostPosted: Mon May 14, 2018 8:01 am    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
My aerial is inside the fuselage, keeps clean doesn’t get knocked works fine.
Kevin Challis
G ODJG
On 14 May 2018, at 16:40, carlp101 <cparkinson(at)cisc-uk.com> wrote:
Hi Christoph,
I've just fitted a VOR/GS antenna on the belly of my Europa Tri-Gear just aft of the hatch for the central tunnel on the underside (see attached pic). It works a treat and it's all signed-off by the LAA inspector! It's a CI 157P antenna. You can either have the V of the antenna pointing forwards or backwards.
Carl
G-URMS
http://forums.matronics.com/viewtopic.php?p=480114#480114
http://forums.matronics.com//files/antenna_fitted_812.jpg
rampil
PostPosted: Tue May 15, 2018 11:56 am    Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
Just because metal fused aircraft needs external vhf antennae, does
not mean it is required for glass aircraft. It only adds drag.
Ira N224XS
AirEupora
PostPosted: Wed May 16, 2018 6:25 am    Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
BOB Archer makes a whole set of antennas for glass aircraft. Aircraft Spruce sells them. I put my VOR antenna in the wing. I can get a good signal fifty to sixty miles away.
http://www.aircraftspruce.com/catalog/avpages/archer_antenna7.php?clickkey=5123597
I hope you have not closed out your wing. If you have then you could built a Balun antenna.
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
