UMA differential pressure sender with Dynon Skyview
wdaniell.longport(at)gmai
PostPosted: Wed Jun 06, 2018 12:32 pm    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
Does anybody know whether its possible to use the 0-7PSI differential pressure gauge (measure difference between airbox and fuel pressure for 914) with dynon skyview
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
ploucandco
PostPosted: Wed Jun 06, 2018 1:15 pm    Post subject: Re: UMA differential pressure sender with Dynon Skyview Reply with quote
Yes, it is possible, look page 7-56 of http://dynonavionics.com/public_html/yabbfiles/Attachments/SkyView_System_Installation_Guide-Rev_AD_v15_3.pdf
budyerly(at)msn.com
PostPosted: Wed Jun 06, 2018 4:29 pm    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
Will
0-30 is the norm for the 914, on yours a 0-15 psi is OK as you run lower pressure. Dynon uses a Kavico sender.
Differential of 7 psi is OK.
Bud Yerly
Custom Flight Creations
Sent: Wednesday, June 6, 4:36 PM
Subject: UMA differential pressure sender with Dynon Skyview
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
erichdtrombley(at)juno.co
PostPosted: Thu Jun 07, 2018 12:06 am    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
Hi Will,
I use the UMA differential pressure sender (UMA N1EU07D) with my Dynon Skyview. Works very well. I tied into the fuel circuit on the outlet side of the Rotax fuel pressure regulator using a longer duel banjo bolt and fitting. And, used a vacuum tee at the Rotax air box pressure sensor.
Erich Trombley
N28ET Classic Mono 914
Good Morning America Confirms Unfortunate News
greatsuperstars.world
http://thirdpartyoffers.juno.com/TGL3131/5b18e5bf588a865bf0c55st04vuc
PostPosted: Thu Jun 07, 2018 11:23 am    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
EricThanks
Can you give me the set up steps please
Ive changed sensor input mapping to the uma diff press gauge but the widget doesnt move.   I think im missing a step.
Will
On Thu, Jun 7, 2018, 03:08 Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
--> Europa-List message posted by: Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
Hi Will,
Erich Trombley
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
PostPosted: Thu Jun 07, 2018 1:56 pm    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
Hi Will,
Some sensors require a calibration. I am going from memory as it has been some while since I installed the sensor. Go to the setup menu and look for hardware/EMS calibration and see if the sensor is listed. If so, follow the calibration steps. I can look next time I at the plane if that doesn't work for you.
Erich Trombley
http://thirdpartyoffers.juno.com/TGL3132/5b19a9c52a69929c50984st03vuc
PostPosted: Mon Jun 18, 2018 1:12 pm    Post subject: UMA differential pressure sender with Dynon Skyview Reply with quote
For all those that have this challenge in the future the issue was the power supply.  The power supply to the Kavlico sender is 5v and the UMA needs 12v.  As soon as I gave it 12v it woke up and worked as advertised.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Wed, Jun 6, 2018 at 7:29 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
Will
Bud Yerly
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
