Landing gear handle "dust"
dsavarese0812(at)bellsout
PostPosted: Mon Jul 02, 2018 4:05 am    Post subject: Landing gear handle "dust" Reply with quote
You should remove and overhaul the landing gear actuators. The rust-colored dust most likely is coming from the actuators.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, July 2, 2018 12:49 AM
Subject: Landing gear handle "dust"
--> Yak-List message posted by: "apatton2" <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)>
Hi all,
I've had a landing gear handle with an intermittent air leak on my Yak-50. I say "intermittent" because it emits a very faint hissing noise when the main air is on... have been flying it this way for ~45h now, and some days the hiss is not audible. Have tried to locate it with soapy water, etc - no joy.
What I have noticed is a slow buildup of rust-colored "dust" around the gear handle (see picture). When the light is "right" during gear extension, I can also see what looks kind of like a puff of some very fine dust come out of the handle.
Is this bad? Have a hopefully irrational fear that my gear system is rusting from the inside out.
Andrew
Andrew Patton
Yak-50
San Francisco, CA
http://forums.matronics.com/viewtopic.php?p=481340#481340
http://forums.matronics.com//files/img_2572_193.jpg
_/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Ybsp; - MATRONICS WEB FORUMS -
http://forums.matr - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
http://www.matronics.com/contrib=======================
