Leaky carb
apatton2
PostPosted: Sun Jul 08, 2018 8:30 pm    Post subject: Leaky carb Reply with quote
Hi All,
I've noticed twice now that my carb (overhauled unit w/ ~50 hrs on it) will leak gas after I land and refuel.
More detail:
    ø It seems to leak through the throat of the carb
    ø It drips once every 3-5 sec
    ø I only have noticed it immediately post-fueling (perhaps it was dripping after shutdown, but I didn't notice)
Today I think it dripped for around 45min after fueling. Weird.
Any thoughts on what could be responsible? When the engine is running I would expect all of this fuel to be sucked into the carb itself. Relative to the amount of fuel an M14 uses this should be trivial.
Many thanks,
Andrew
Andrew Patton
Yak-50
San Francisco, CA
dsavarese0812(at)bellsout
PostPosted: Mon Jul 09, 2018 3:11 am    Post subject: Leaky carb Reply with quote
Call whoever overhauled the carburetor for you and tell them the carb is leaking and ask them to repair it.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, July 9, 2018 12:33 AM
Subject: Leaky carb
--> Yak-List message posted by: "apatton2" <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)>
Hi All,
More detail:
Many thanks,
Andrew
Andrew Patton
Yak-50
San Francisco, CA
http://forums.matronics.com/viewtopic.php?p=481500#481500
http://www.matronics.com/Np; - MATRONICS WEB FORUMS -
<; --> http:/nbsp; - NEW MATRONICS LIST WIKI -matronics.com/" target="_blank">http://wiki.matronics.com
; -Matt Draltp://www.matronics.com/contribution" target="_blank">http://www.matronics==
richard.goode(at)russiana
PostPosted: Mon Jul 09, 2018 3:30 am    Post subject: Leaky carb Reply with quote
We overhauled it, and of course stand by it! Normally I would put it down to a faulty membrane, but it was new and therefore most unlikely. But I suspect it is a sticking fuel valve. We will be looking into it.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: 09 July 2018 12:11
Subject: Re: Leaky carb
Dennis
From: apatton2 <apatton(at)alumni.princeton.edu (apatton(at)alumni.princeton.edu)>
Subject: Leaky carb
Hi All,
More detail:
Many thanks,
Andrew
Andrew Patton
Yak-50
San Francisco, CA
bwade154(at)yahoo.com
PostPosted: Mon Jul 09, 2018 4:27 am    Post subject: Leaky carb Reply with quote
Just because I'm a curious kind of guy after it stops leaking and you pressurize the system side with the primer does it start leaking again?
On ‎Monday‎, ‎July‎ ‎9‎, ‎2018‎ ‎12‎:‎41‎:‎27‎ ‎AM‎ ‎EDT, apatton2 <apatton(at)alumni.princeton.edu> wrote:
Hi All,
More detail:
Many thanks,
Andrew
Andrew Patton
Yak-50
San Francisco, CA
http://forums.sp; - NEW MATRONICS LIST WIKI -
apatton2
PostPosted: Sun Jul 15, 2018 7:04 pm    Post subject: Re: Leaky carb Reply with quote
What's interesting is that I tried shutting off the plane today by pulling the fuel shutoff valve several times. The engine dies around 10sec later, but the carb still drips! Was not expecting that.
Andrew Patton
Yak-50
San Francisco, CA
