Fuel fumes in the cockpit
saber369(at)comcast.net
PostPosted: Sun Aug 12, 2018 11:59 am    Post subject: Fuel fumes in the cockpit Reply with quote
Im getting fuel fumes in the cockpit in my stock CJ with stock motor. I don’t smell anything during ground operations or when full throttle ops on take off. When I get to about 4000 feet and open the throttle all the way I start smelling gas. When I back off to less than full throttle or about 3/4 throttle the smell seems to go away. Opening and closing the canopy doesn’t seem to have much effect on the fumes. The fumes aren’t overwhelming... but they do persist and seem to be associated with full throttle.
I removed the cowling; washed the engine and then had someone pressurize the fuel system using the wobble pump while I inspected the engine compartment looking for leaks... nothing. There was a slight hint of fuel vapors around the bottom of the carb but nothing too strong and certainly no dripping.
I’m open to any suggestions and even guesses at this point.
JB
Sent from my iPad
pfstelwagon(at)earthlink.
PostPosted: Sun Aug 12, 2018 12:55 pm    Post subject: Fuel fumes in the cockpit Reply with quote
Pull the belly panels and carefully examine the fuel sump tank for leaks. Water will migrate to the sump and cause corrosion.
Frank
On Aug 12, 2018, at 12:59 PM, Jon Blake <saber369(at)comcast.net> wrote:
PS
PostPosted: Sun Aug 12, 2018 1:01 pm    Post subject: Re: Fuel fumes in the cockpit Reply with quote
You may also want to pull the wing root covers and see if the line from the tank to the fuselage is seeping.
Phil
Phil
wlannon(at)shaw.ca
PostPosted: Sun Aug 12, 2018 6:30 pm    Post subject: Fuel fumes in the cockpit Reply with quote
Jon;
Sounds like possibility of a vent system problem. Check the wing joint
connections as Phil has suggested and check for blockage of the inlet.
The highest point of the system is right beside your left shoulder. A
corrosion pin hole here could be the source.
Walt
Viperdoc
PostPosted: Mon Aug 13, 2018 5:50 pm    Post subject: Fuel fumes in the cockpit Reply with quote
What happened to Gary Gabbard. RPA is having a memorial for him.
Doc
Sent from my iPad
[quote] On Aug 12, 2018, at 9:30 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Jon;
Sounds like possibility of a vent system problem. Check the wing joint connections as Phil has suggested and check for blockage of the inlet.
The highest point of the system is right beside your left shoulder. A corrosion pin hole here could be the source.
Walt
Viperdoc
