Easy fuel valve modification
rickofudall
PostPosted: Wed Aug 29, 2018 4:10 pm    Post subject: Easy fuel valve modification Reply with quote
Take a Weatherhead 3 way valve drill through one side of the ball so that it's now a tee rather than an ell. Now plumb so that you have a 172 standard left, right, both, off valve. If you need to use all the fuel in a tank you can dial in that tank, suck it dry and move to the other tank without losing the engine while making the transfer. It was not the brightest day but it did get me home.
Rick Girard
“Blessed are the cracked, for they shall let in the light.”   Groucho Marx
mojaveclimber
PostPosted: Wed Aug 29, 2018 10:48 pm    Post subject: Easy fuel valve modification Reply with quote
Rick
Reference Far 23.951  Essentially no low wing aircraft may have a both fuel position for the fuel select valve.  Same case for our Kolbs engine above fuel tanks.  The intent is that we not be able to run one tank dry, suck air in the dry tank, and not figure out the error before a fuel starvation landing event.
Jim
Kolb Mk 3
Cherokee 140
On Wed, Aug 29, 2018 at 5:12 PM Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
