Ragwing Ultra-Piet
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
cdlwingnut
PostPosted: Fri Oct 05, 2018 7:36 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
The fourth spar is glued and drying in the jig. Running low on t88 so need to get more ordered before moving on with the plywood webbing..
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
 Filesize:  227.51 KB
 Viewed:  1404 Time(s)
bickers.ken(at)gmail.com
PostPosted: Fri Oct 05, 2018 8:39 am    Post subject: Ragwing Ultra-Piet Reply with quote
Our local Woodcraft store keeps T-88 in stock.  If you have one of those nearby, maybe you can skip the time and cost of shipping. Nice work, by the way.
On Fri, Oct 5, 2018 at 9:39 AM cdlwingnut <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "cdlwingnut" <lee_chad(at)hotmail.com (lee_chad(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=483617#483617
http://forums.matronics.com//files/20181005_094440_resized_143.jpg
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
cdlwingnut
PostPosted: Mon Nov 19, 2018 4:53 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have gotten the spars done and have slid the ribs onto the rear left spar. That stack of ribs that have been laying around are starting to look like a wing.
 Filesize:  210.95 KB
 Viewed:  1083 Time(s)
 Filesize:  255.81 KB
kipgohio1957(at)gmail.com
PostPosted: Mon Nov 19, 2018 5:34 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Good to hear!
http://forums.matronics.com/viewtopic.php?p=485322#485322
http://forums.matronics.com//files/20181119_151826_resized_220.jpg
http://forums.matronics.com//files/20181119_151830_resized_203.jpg
cdlwingnut
PostPosted: Tue Dec 11, 2018 3:52 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Spars were jigged, checked for square. Ribs jigged and checked for square again. T88 was mixed and applied. Once again checked for square. Then little tinny nails tack hammered to nail the ribs to the spars while t88 dries. Checking for square many more times in the process. The whole time thinking boy these nails are small and i really really hope its square when done.
 Filesize:  224.68 KB
 Viewed:  812 Time(s)
 Filesize:  284.47 KB
 Viewed:  812 Time(s)
taildrags
PostPosted: Tue Dec 11, 2018 8:57 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Cdlwingnut: does the Ultra-Piet have full-span ailerons? The rib tails all look like they are set up to be cut out to make ailerons.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
cdlwingnut
PostPosted: Wed Dec 12, 2018 4:07 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
No only the outer 5 ribs get cut for alierons
cdlwingnut
PostPosted: Thu Jan 17, 2019 5:04 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have been working on nose ribs and have started assembling the right wing. I have also been working on lots of smaller projects, those are tough because you don't see the progress as much but still need to be done
 Filesize:  247.89 KB
 Viewed:  528 Time(s)
 Filesize:  240.1 KB
 Viewed:  528 Time(s)
 Filesize:  264.53 KB
 Viewed:  528 Time(s)
PostPosted: Thu Jan 17, 2019 5:37 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Looks good!
http://forums.matronics.com/viewtopic.php?p=487063#487063
http://forums.matronics.com//files/20190110_112302_resized_129.jpg
http://forums.matronics.com//files/20190116_164126_resized_147.jpg
http://forums.matronics.com//files/20190104_152503_resized_680.jpg
taildrags
PostPosted: Sat Jan 19, 2019 11:39 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Dude, you've got some serious moisture intrusion problems on that concrete masonry wall ;o) Looks like you're building in a basement, or maybe partial daylight basement, with at least that back corner and most of one wall below grade. Not sayin' that's black mold growing in the corner, but it's at least mildew.
Back to regularly-scheduled airplane building ;o)
Oscar Zuniga
Medford, OR
cdlwingnut
PostPosted: Mon Feb 04, 2019 6:11 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
i was feeling brave enough to try cutting the slots in my vertical fin and rudder to install the hinges. I just went slow and took my time to cut sand and slide the hinges in then some careful work with the drill I managed to install the bolts to hold them together. No the bolts in the picture aren't locking as i will have to take the hinges off a few times for covering and such they will be locking bolts for the final assembly.
 Filesize:  249.29 KB
 Viewed:  305 Time(s)
cdlwingnut
PostPosted: Wed Feb 06, 2019 6:29 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
finally got the shop warm enough for T-88 so I got the nose ribs on the left wing and installed the false rib for the ailerons.
 Filesize:  220.76 KB
 Viewed:  263 Time(s)
 Filesize:  207.31 KB
 Viewed:  263 Time(s)
cdlwingnut
PostPosted: Thu Feb 07, 2019 12:29 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
did some more work on my left wing, I installed the leading edge strip and the wingtip dowel. I also glued in the aileron spar.
 Filesize:  199.5 KB
 Viewed:  245 Time(s)
 Filesize:  229.29 KB
 Viewed:  245 Time(s)
cdlwingnut
PostPosted: Sat Feb 09, 2019 4:55 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
the shop was a little cold to comfortably work with t-88 so i cut and beveled the gussets for the trailing edge piece. I then put on a coat of varnish on the leading edge parts that won't be accesable once the leading edge plywood is on.
cdlwingnut
PostPosted: Mon Feb 11, 2019 5:45 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
still working on the left wing. The trailing edge is installed and i figured out how i want to do the wing tips, the plans are a little vague on this part so after some though this is what i came up with
 Filesize:  221.78 KB
 Viewed:  169 Time(s)
 Filesize:  218.1 KB
 Viewed:  169 Time(s)
 Filesize:  241.36 KB
 Viewed:  169 Time(s)
PostPosted: Mon Feb 11, 2019 6:47 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Looking good,
I hope to start on one of these in a year or so, I’ve enjoyed seeing your progress. I wish there were still more people using this forum, i think the format is more conducive to real info exchange than Facebook.
Kip Gardner
http://forums.matronics.com/viewtopic.php?p=487540#487540
http://forums.matronics.com//files/20190211_121719_resized_180.jpg
http://forums.matronics.com//files/20190211_121816_resized_514.jpg
http://forums.matronics.com//files/20190211_121828_resized_972.jpg
cdlwingnut
PostPosted: Mon Feb 11, 2019 7:21 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
thanks Kip
I do like this format for showing build progress, I would love so see others who are building use it too. It is fun watching a bunch of sticks and some plywood slowly turn into an airplane.
glen
PostPosted: Mon Feb 11, 2019 7:36 pm    Post subject: Ragwing Ultra-Piet Reply with quote
Hi Kip
I’ve been a member of this forum for a couple of years. I like the people and the format...so much amazing information
My partner set me up with Brodhead Pietenpol Association. Same great people plus a bunch more , all the information you find here,plus,once again, a bunch more. If you haven’t already, you might want to check it out. That’s something you can do without giving mr zuckerberg your data Blue skies!
On Feb 11, 2019, at 6:46 PM, Kip Gardner <kipgohio1957(at)gmail.com> wrote:
Looking good,
Kip Gardner
View user's profile Send private message Send e-mail Yahoo Messenger
cdawson5854(at)shaw.ca
PostPosted: Tue Feb 12, 2019 1:32 am    Post subject: Ragwing Ultra-Piet Reply with quote
Facebook has only one mandate. Take every last bit of your life and
sell it to any and all businesses that will make a profit off it.
That goes for gubmint also. Big Time!
Anyway, enough rant. I've now got my very own hanger space at
Delta Heritage Airpark, CAK3, in Delta, BC, Canada.
http://www.deltaheritageairpark.org/
I'm getting closer and closer to the frame inspection. I need a 72"
tach cable and two 90° fittings. I'm saving up for that. When
the weather gets better I'll be doing the fuel system leak test
and fuel flow test. Also compass swinging. There's some
nuts and bolt stuff to take care of. OH! and the engine cowling
to design and make. 90% done 90% to go!
And then there's the prop to make!!
These pics are in the temporary space. My new permanent space
is three spaces right, at the very end of the hanger.
Clif
Fill what's empty, empty what's full, fart joyously, carry matches.
<glenschweizer(at)yahoo.com>
Hi Kip
Blue skies!
 Filesize:  132.2 KB
 Viewed:  149 Time(s)
 Filesize:  137.45 KB
 Viewed:  149 Time(s)
taildrags
PostPosted: Tue Feb 12, 2019 8:14 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Clif; after dealing with an awkwardly-routed tach cable on my airplane, I sprung for one of those 90 degree cable adapters from Aircraft Spruce. About $70 USD, works great.
Oscar Zuniga
Medford, OR
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 5 of 6
