Trailered Europa
jglazener
PostPosted: Wed Nov 14, 2018 2:00 pm    Post subject: Trailered Europa Reply with quote
Could someone give me the dimensions (HxWxL) of a trailered Europa? Loooking at a new house and being able to get it in the garage would be a definite plus
Jeroen
http://www.europaowners.org/main.php?g2_itemId=44165
Phil B
PostPosted: Thu Nov 15, 2018 6:23 am    Post subject: Re: Trailered Europa Reply with quote
Jerome,
My monowheel trailer with the aircraft on it is 2m wide, the top of the tail is 1.92m high (but this depends on the height of the dolly wheel) and 6.15m long from the tow hitch to the end of the a/c spinner.
Hope this helps.
Phil B
jglazener
PostPosted: Thu Nov 15, 2018 12:44 pm    Post subject: Re: Trailered Europa Reply with quote
Hello Phil, thanks for your reply. I should have mentioned in my post that I have a trigear. Do you know how that affects the dimensions? I assume it is only the height of the tailplane that is different.
Jeroen
Phil B
PostPosted: Fri Nov 16, 2018 12:31 am    Post subject: Re: Trailered Europa Reply with quote
Jeroen,
Sorry, no idea on the tri gear dimensions on its trailer.
Phil B
Roland
PostPosted: Fri Nov 16, 2018 7:38 am    Post subject: Re: Trailered Europa Reply with quote
Hi Jeroen,
I have my Trigear stored in an enclosed Trailer from Anschau. It's about 2,5 m wide and 8,5 m long and I suppose it's about the "worst case".
Roland
PH-ZTI
XS TG 914
