Anybody use stock fuel valve?
digidocs
PostPosted: Tue Jan 15, 2019 5:26 pm    Post subject: Anybody use stock fuel valve? Reply with quote
Hi all,
Has anyone on this list fitted the stock fuel valve?  Any tips for making the installation look more polished or operate as well as possible?  I can find very little online about it.
FYI---not really interested in going the Andair valve option.
Thanks!
n520tx(at)gmail.com
PostPosted: Tue Jan 15, 2019 5:43 pm    Post subject: Anybody use stock fuel valve? Reply with quote
I installed the stock valve as per the plans - not a single change. It
does the job, never saw a need to modify it.
It's a bit of a nuisance to have to remove the handle every time you
want the tunnel cover removed, but what can ya do, it's only once a year.
--Ron
On 1/15/19 7:13 PM, David Carr wrote:
Hi all,
Thanks!
BrBreck
PostPosted: Tue Jan 15, 2019 7:57 pm    Post subject: Anybody use stock fuel valve? Reply with quote
Great question.  I installed the Andair Valve in another plane, and, it works sweetly.  I was hoping to go "stock" on the -10 project.  Hoping more than just Mr. Walker speaketh up.
Bruce
40018
On Tue, Jan 15, 2019 at 5:30 PM David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
Hi all,
Thanks!
rleffler
PostPosted: Tue Jan 15, 2019 8:48 pm    Post subject: Anybody use stock fuel valve? Reply with quote
Just about every RV-10 that I’m aware of, including mine has gone with an Andair valve. Mine has been flying for over six years, so I haven’t really bothered to keep up with all the factory parts quality control issues. Hopefully, that vendor has fixed their issues over the years. I don’t have any data, pro or con.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com on behalf of Bruce Breckenridge <bbreckenridge(at)gmail.com>
Sent: Tuesday, January 15, 2019 11:06 PM
Subject: Re: Anybody use stock fuel valve?
Bruce
40018
Hi all,
Thanks!
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
kboatright1(at)comcast.ne
PostPosted: Tue Jan 15, 2019 9:08 pm    Post subject: Anybody use stock fuel valve? Reply with quote
I have the stock valve in my RV-6, and it is doing fine after 18 maintenance
free years.
I installed the stock valve in the RV-10 I'm finishing and have no qualms
about it. The installation is very simple - just follow the plans.
Kyle Boatright
Bob Turner
PostPosted: Tue Jan 15, 2019 9:59 pm    Post subject: Re: Anybody use stock fuel valve? Reply with quote
Stock valve in mine. Kit purchase circa 2008, just in time to get the slightly modified valve with the new handle (aluminum pointer, lift-to-turn). The older brass handle was just plain ugly IMHO. No problems to date.
Bob Turner
RV-10 QB
gspecketer(at)gmail.com
PostPosted: Wed Jan 16, 2019 5:07 am    Post subject: Anybody use stock fuel valve? Reply with quote
I installed the stock valve 11 years ago and have had no problems. If you push down on the valve during loading it can make it move hard. Just pull up on the handle and release and your good to go.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com on behalf of David Carr <junk(at)dcarr.org>
Sent: Tuesday, January 15, 2019 8:31 PM
Subject: Anybody use stock fuel valve?
Hi all,
Thanks!
arvaijw(at)gmail.com
PostPosted: Wed Jan 16, 2019 7:30 am    Post subject: Anybody use stock fuel valve? Reply with quote
I use the stock valve in my RV-10.  2.5 yrs and no issues.
Joe
On Tue, Jan 15, 2019 at 8:31 PM David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
Hi all,
Thanks!
avu1(at)md.metrocast.net
PostPosted: Wed Jan 16, 2019 1:48 pm    Post subject: Anybody use stock fuel valve? Reply with quote
No issues in 10 years. Anh
On Jan 16, 2019, at 10:27 AM, Joe arvai <arvaijw(at)gmail.com (arvaijw(at)gmail.com)> wrote:
Joe
Hi all,
Thanks!
timrvator(at)comcast.net
PostPosted: Wed Jan 16, 2019 2:11 pm    Post subject: Anybody use stock fuel valve? Reply with quote
8 years, 1150 hrs, no issues. Stock valve, unpainted, per plans. I lightly coat the nylon w/ fuel lube every few years if it gets hard to turn.
Same experience with my RV-6A for 1100 hrs.
On Jan 16, 2019, at 4:31 PM, DejaVu <avu1(at)md.metrocast.net (avu1(at)md.metrocast.net)> wrote:
Joe
Hi all,
Thanks!
Jim Combs
PostPosted: Wed Jan 16, 2019 3:48 pm    Post subject: Anybody use stock fuel valve? Reply with quote
I used the stock fuel selector valve.  First flight in 2010, 1000+ hours no issues.
Jim C (N312F)
On Tue, Jan 15, 2019 at 11:52 PM Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) on behalf of Bruce Breckenridge <bbreckenridge(at)gmail.com (bbreckenridge(at)gmail.com)>
Bruce
40018
Hi all,
Thanks!
RV-10 -> N312F - Flying as of 12/2008
sportav8r(at)gmail.com
PostPosted: Thu Jan 17, 2019 5:35 am    Post subject: Anybody use stock fuel valve? Reply with quote
My kit came with the Andair.  Much nicer than the stock valve in my 6A.  I have a stock -10 valve for sale Smile
On Wed, Jan 16, 2019 at 6:52 PM Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Jim C (N312F)
Get Outlook for iOS
Bruce
40018
Hi all,
Thanks!
rvdave
PostPosted: Wed Jan 23, 2019 9:05 am    Post subject: Re: Anybody use stock fuel valve? Reply with quote
I’ve used the stock valve in my 6, it got stiff on me once but disassembled and lubed, no problem since. Using the stock valve on my 10 and no problems, using the red pointer knob.
Dave Ford
Cadillac, MI
