Noise cancelling headsets , do you wear them in a CJ or Yak
pennington.construction.i
PostPosted: Fri Feb 22, 2019 10:02 am    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
I would contact the folks you purchased the plane from and see what they used etc.
I use A20s.  Love them.   I had a small issue before I switched to mono from stereo.
Good luck
Mark
On Fri, Feb 22, 2019 at 11:06 AM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Maybe my audio panel is the issue.
www.Backcountry182.com
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=487741#487741
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
PostPosted: Fri Feb 22, 2019 10:16 am    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
Good luck
Mark
Cessna 182 P
CJ -6
FORUMS -
WIKI -
b Site -
draftsjust417(at)gmail.co
PostPosted: Fri Feb 22, 2019 3:38 pm    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
My 2 cents worth: I personally use my 20+ yr old David Clarks in my CJ6.Friends who ride in the back with their Bose, etc w/ noise cancelling tell me they develop an unpleasant throbbing.
While I use Bose & Lightspeed headsets for work (KingAirs), my DC's are ideal for the radial monsters.
Again, my 2 cents worth-
Justin Drafts
N280NC
On Fri, Feb 22, 2019 at 8:36 PM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
Cessna 182 P
CJ -6
FORUMS -
WIKI -
b Site -
hill(at)doctor-hill.com
PostPosted: Wed Feb 27, 2019 10:15 am    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
In the CJ cockpit with the M-14P engine, the Bose A20 works great.
On Feb 27, 2019, at 10:46 AM, LawnDart <propwash(at)gmail.com> wrote:
Rob737998 wrote:
I would be interested if other Yak pilots have experienced the same when using a Bose A20.
Yes, I had a similar experience. After flying my 52 for many years, I could not get use to (or trust) the muted sound. Same as you, the A20 went to the rear cockpit and I returned to my DC.
http://forums.matronics.com/viewtopic.php?p=487837#487837
drc(at)wscare.com
PostPosted: Wed Feb 27, 2019 1:43 pm    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
I have the Lightspeed Zulu They do not work well in the Yak either.  I also fly a Breezy in the summer.  No ANR works well with it either due to noise.
The best Passsive NR headset I have found that is really comfortable is this:
Faro G2 - More comfortable than a David Clark, great PNR, Inexpensive.
https://www.marvgolden.com/faro-g2-passive-aviation-headset.html?gclid=EAIaIQobChMIqbKC1-_c4AIVWp7ACh0JYQWbEAQYBSABEgK05fD_BwE#75=2
I also notice that ANR do not work properly if the seal around the ear is perfect.
The Bose does not fit my big ears as well - thus Lightspeed.
And if I wear glasses with thicker temple pieces over the ear it disrupts the seal. I have an old pair of wire frame that do not disrupt the seal.
[quote] On Feb 27, 2019, at 11:05 AM, Rob737998 <robertjamesharper(at)gmail.com (robertjamesharper(at)gmail.com)> wrote:
--> Yak-List message posted by: "Rob737998" <robertjamesharper(at)gmail.com (robertjamesharper(at)gmail.com)> I have a set of Bose A20â?Ts I have used in my Yak 52. I have to say with the ANR switched on I couldnâ?Tt get on with them. They made the radial engine sound like it had dumped all the oil in it overboard. I kept having to pull the ear cup off my ear to make sure the engine was sounding right. In the end I have reverted back to my David Clarkâ?Ts which work well. The Bose have become a very expensive headset for my passengers. I made a complaint to Bose who responded back in saying that they had received a few similiar complaints. They admitted that there headsets would not suit every type of aircrafts particular engine harmonics. I really would like to try a set of Lightspeed Zulu headsets in the YAK. I think Lightspeed are offering your money back if you are happy. I will give them a try and report back. I would be interested if other Yak pilots have experienced the same when using a Bose A20. My advice would be to try a headset before you buy if you can. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487836#487836
drc(at)wscare.com
PostPosted: Sat Mar 02, 2019 3:28 pm    Post subject: Noise cancelling headsets , do you wear them in a CJ or Yak Reply with quote
I have chimed in on my affection for Lightspeed. And the inability to use ANR in the yak or on a breezy. Yes you fly on a breezy, not in it.
I use a nice inexpensive Passive noise reduction on the breezy, but I also use a Gibson and Barnes helmet w CEP in the yak. This works great.
Sent from DrC(at)wscare.com on the iPhone. Please excuse spelling and autocorrect. Siri makes mistakes Smile.
On Mar 2, 2019, at 4:46 PM, jay-dub <flyjnw(at)gmail.com> wrote:
I use CEP-USA in-ear plugs with custom ear molds inside an Alpha Eagle dome, although they are almost as effective in my HGU. I much prefer them to ANR in the CJ and Yak.
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=487891#487891
