Brake Pressure
jonboede(at)hotmail.com
PostPosted: Wed Mar 27, 2019 8:41 pm    Post subject: Brake Pressure Reply with quote
Reading the maintenance manual, it seems like the QS-1 valve is supposed to go from 0 to 0.95Mpa (138psi) in 2.2 seconds or less...
Is 138psi a good value for the maximum pressure for the brake at the wheel?
Jon
wlannon(at)shaw.ca
PostPosted: Mon Apr 01, 2019 9:37 am    Post subject: Brake Pressure Reply with quote
Jon;
I set mine to 9 Atm (130 psi). Works fine.
Walt
Sent: Wednesday, March 27, 2019 9:41 PM
Subject: Brake Pressure
Jon
