Don Emch W&B Data, aka Cure for Insomnia
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
airlion2(at)gmail.com
PostPosted: Sat Mar 22, 2014 1:35 pm    Post subject: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
Don,I have the jig now and in the process of figuring out how to make it 2 inches wider. Gardiner
On Mar 22, 2014, at 3:21 PM, "Don Emch" <EmchAir(at)aol.com> wrote:
Well just in case any of you are having a tough time falling asleep tonight.... or if you want to laugh at a very amateurish hand drawn Weight and Balance sheet.... here it is.
For quick background. Essentially it is a "plans built" (according to Don Emch, Ha!) airframe. Long fuselage with plans built steel split axle gear. I followed the plans the best I could with the exception of brakes, small tailwheel, nose tank, slanting the cabanes back 3.5" and cheating slightly on the A-65 engine mount by extending it about 1". As far as I know that is about all I did. (Hopefully I can still sit on the Top Curmudgeon Board). According to my measurements here, my wing leading edge is 6" forward of the axle. Which if you look at the plans and note that I moved the wing back 3.5" then you'll see that the axle is located according to plans. I really think that moving the wing back is key for both weight and balance and being able to keep the axle at plans location while using brakes. A lot more is accomplished versus extending the engine mount. My seat, baggage, and fuel "arms" were derived by actually putting fuel, baggage and people in those loca!
tions while on the scales and working the math backwards to get accurate arm lengths. A couple of scenarios are given as samples in flight conditions too. You can see with me at about 185 lbs. and running the tank dry I approach the aft limit... but then I'll probably have a few other things on my mind at that point.
Interestingly, It feels the nicest in flight when the C.G. is hovering around the 17" - 18" aft of leading edge area. I think that wing likes it there.
Don Emch
NX899DE
http://forums.matronics.com/viewtopic.php?p=420853#420853
http://forums.matronics.com//files/piet_weight_and_balance_data_456.pdf
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Don Emch
PostPosted: Sat Mar 22, 2014 2:08 pm    Post subject: Re: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
Can you just go to the outside of the angle iron? Would that get it close to where you wouldn't need to actually change the fixture?
Don Emch
NX899DE
PostPosted: Sat Mar 22, 2014 2:30 pm    Post subject: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
Thanks don, I will try that tomorrow, Gardiner
Don Emch
NX899DE
http://forums.matronics.com/viewtopic.php?p=420864#420864
kratos
PostPosted: Sat Apr 13, 2019 7:33 am    Post subject: Re: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
I haven`t been sleeping very well lately. Instead of drinking beer, I think to try https://worldpharm365.com/product/etizolam-etilaam-etizest-2mg-buy-with-bitcoin/ Etizolam. As it is stated, this is not a sleeping in the normal sense of the word, but the natural regulator of the sleep rhythms. No inhibition in the morning, however, as well as no other side effects. What do you say?
bradandlinda(at)tds.net
PostPosted: Sat Apr 13, 2019 8:25 am    Post subject: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
Insomnia isn't really that serious..it's certainly not worth loosing any sleep over.
gjkaal
PostPosted: Sat Apr 13, 2019 11:13 pm    Post subject: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
Looks like a possible trojan/malware, with a link that contains references to bitcoins.
On Sat, 13 Apr 2019 at 17:36, kratos <steamcsgogrizzly(at)gmail.com (steamcsgogrizzly(at)gmail.com)> wrote:
--> Pietenpol-List message posted by: "kratos" <steamcsgogrizzly(at)gmail.com (steamcsgogrizzly(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=488712#488712
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
GJH Kaal
Building a Pietenpol air camper
steven.d.dortch(at)gmail.
PostPosted: Sun Apr 14, 2019 5:13 am    Post subject: Don Emch W&B Data, aka Cure for Insomnia Reply with quote
I wasn't fooled. If you combine Bitcoin and a Pietenpol they spontaneously combust!
On Sun, Apr 14, 2019, 2:15 AM Gerrit-Jan Kaal <gjhkaal(at)gmail.com (gjhkaal(at)gmail.com)> wrote:
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
