Tim_Lewis(at)msm.umr.edu Guest
Posted: Mon Jan 16, 2006 7:25 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
Listers,
I've fabricated a pretty inexpensive cabin door lock for my RV-10. It
seems to work well.
Photos and text are at my web page,
<http://home.earthlink.net/~timrv6a>. Scroll down near the bottom, and
click the "Door Locks" link.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 830 hrs
RV-10 #40059 under construction
LarryRosen
Posted: Mon Jan 16, 2006 7:50 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
I like the solution. Now where are you going to get the 3rd lock for
the passenger side?
Another door lock solution is by Palle Olesen here <http://www.rv10.dk/>
to the bottom of the page. Not as simple as Tim's.
Larry Rosen
#40356
<http://lrosen.nerv10.com>
Tim Lewis wrote:
Quote: |
Listers,
seems to work well.
and click the "Door Locks" link.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tdawson(at)avidyne.com Guest
Posted: Mon Jan 16, 2006 8:03 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
Nice!
TDT
40025
coop85(at)bellsouth.net Guest
Posted: Mon Jan 16, 2006 8:06 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
I had the same thought. One possibility would be to have a simple lock on
the inside (2x4 against the handle ) and only have a true external
accessible lock on the pilot's side.
Marcus
the passenger side?
Larry Rosen
#40356
Tim Lewis wrote:
Quote: |
Listers,
seems to work well.
TimRvator(at)comcast.net Guest
Posted: Tue Jan 17, 2006 5:26 am Post subject: Inexpensive RV-10 Cabin Door Lock |
I plan to lock the passenger door from inside only -- no external lock.
One very simple method would be to drill a pair of vertically-oriented holes through the interior door handle on the forward, outboard corner. To lock the door, drop a bolt or nail thru the hole pair. This would prevent the latch from being pressed, so the handle could not be rotated.
Tim Lewis
RV-6 N47TD -- 830 hrs
RV-10 N31TD (reserved)
dlm46007(at)cox.net Guest
Posted: Tue Jan 17, 2006 6:29 am Post subject: Inexpensive RV-10 Cabin Door Lock |
About those locks with identical keys. Some one has already posted several months ago about a source in WA. I bought three packages with two locks in each all identically keyed for $20 total. Identical to the aviation lock except the retaining washer for the inside. We will fab a washer or glue the locknut in place.
ddddsp1(at)juno.com Guest
Posted: Tue Jan 17, 2006 8:46 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
Tim,
Can you give the dimensions of your LOCK for the RV 10 door? Size of hole in door.........length of cam lock........length of locking bar..............etc. I have seen several locks like this on office furniture.........desk drawers, file cabinets, curio cabinets........etc.
DEAN
Posted: Tue Jan 17, 2006 9:27 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
Sorry,,,,,,,,forgot to include the website on my previous reply.
http://www.mrlock.com/eshop/locks/mfg/esp/ulrcam.html?mv_pc=go_camlk#
DEAN
schmoboy(at)cox.net Guest
Posted: Tue Jan 17, 2006 10:09 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
I mentioned this a while ago on the list, but wasn't sure if it would
work for a door lock. I'm not familiar with Zinc in relation to
corrosion, so not sure about that. I was planning on attempting to use
this for the baggage door lock, but it may be reasonable for a door lock
also? I like the idea of a combination as opposed to a key as I am
prone to loosing them.
<http://www.rockler.com/ecom7/product_details.cfm?&offerings_id=11231>
Comments?
-Sean #40303 (Not far enough along to think *too* hard about locks yet)
http://rv10.stephensville.com
Deems Davis
Posted: Tue Jan 17, 2006 10:46 pm Post subject: Inexpensive RV-10 Cabin Door Lock |
I like the combination lock idea, as I share in the lost-key syndrome.
It appears that the lock protrudes quite away out from the surface, and
that's a bit of a turnoff for me. don't have a clue as to zinc's
corrosive properties.
Deems Davis # 406
Wings (Fuse arrived today !!!!!!!! )
http://deemsrv10.com/
use this for the baggage door lock, but it may be reasonable for a
door lock also? I like the idea of a combination as opposed to a key
as I am prone to loosing them.
Comments?
> DEAN
