[esqualtalk] Lightning Flight review
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
pete(at)flylightning.net
PostPosted: Thu Jul 20, 2006 1:02 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
Hi Everyone,
Make sure to stop and see Buz Rich’s Esqual LS  (Lightning Stuff) airplane at OSH.  It is parked in the first row by the big arch main entrance to the flightline (prime spot!).  For sure this is the best looking Esqual ever and the fastest one as well.  Certainly worth a look if you at Airventure.
Pete
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Sunday, July 16, 2006 8:55 AM
Subject: Re: [esqualtalk] Lightning Flight review
Hi Laurie,
    Your glider comparison to landing the Esqual is right on.  In fact, flying it is probably somewhat like flying a motor glider that can go really fast.  I have never flown a motor glider (I do have a commercial glider rating) but with the relatively long, high aspect ratio wing and the 19 to 1 glide ratio, the Esqual does not want to stop flying.  Speed control on final is important to get down and stopped short.  Also, down low on a hot bumpy day, the Esqual can be a somewhat uncomfortable ride unless you slow down.  Of course that same wing allows you to get high in a hurry and be above the bumpy air and utilize the fast cruise speeds.
    Good point on using the Lightning's full 45 degrees of flaps to insure short landings, as you say, into someone's back yard.  It would certainly allow a really steep approach.  And it is always good to have extra "tricks" in your "bag of tricks" when something goes wrong.  The reason I mentioned that is the high drag situation (45 flaps) kind of puts you behind the "power curve" and really took a long time to reestablish a climb rate during my dirty stalls and that could potentially be a problem on a last minute go around.  Your mileage may vary.  Another thought that I think I failed to mention - the Lightning's rudder authority and rudder pressures are slightly better and slightly lighter than my Esqual.  Therefore, I found that slips were a little easier and more effective in the Lightning.  So that is another "trick" for your "bag of tricks" that you will have on board.
    At this point I would think that the tail dragger Lightning is just a future thought.  The guys in Shelbyville are just too busy now to work on the changes, but I am fairly confident that if will happen - sometime.  Some future builder may beat them to it.  I should be a relatively easy modification once the geometry of the main gear is worked out.  I can see two ways to do that - either added to the motor mount angled aft, or added to the central beam assembly (as is the current main gear) at the proper angle.  Adding the tail wheel would probably be the easy part.  But it sure would be a great looking airplane.  Not that it isn't already.
Blue Skies,
Buz
PS:  Leg pulling? Maybe a little.
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
sky2000diver(at)yahoo.com
PostPosted: Thu Jul 20, 2006 1:33 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
Can anyone help me with some questions about the
lightning? john
--- owner-lightning-list-server(at)matronics.com
<pete(at)flylightning.net> wrote:
Hi Everyone,
Make sure to stop and see Buz Rich's Esqual LS
you at Airventure.
Pete
_____
On Behalf Of
N1BZRich(at)aol.com
Hi Laurie,
right on. In fact,
a commercial glider
speeds.
puts you behind the
will have on board.
relatively easy
gear) at the proper
isn't already.
Blue Skies,
Buz
PostPosted: Thu Jul 20, 2006 2:06 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
Ask away!
Pete
PostPosted: Thu Jul 20, 2006 2:23 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
I live near detroit michigan, and would like to find
someone close that can show me a lightning as im
interested in purchasing a lsa.
Ask away!
Pete
PostPosted: Thu Jul 20, 2006 3:10 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
No Lightnings near Detroit yet. Catch us at OSH or visit us in Tennessee.
Pete
PostPosted: Thu Jul 20, 2006 6:47 pm    Post subject: [esqualtalk] Lightning Flight review Reply with quote
Work load doesnt allow me to get away for a weekend or
during the week. A road trip just isnt possible right
now to check out this aircraft but have taken a demo
flight on the ct by flight design and really like it
but like the written stats of the lightning
better....so, im stuck for now.
Pete
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
