Kolb-List Digest: 4 Msgs - 06/29/19
byoungplumbing(at)gmail.c
PostPosted: Sun Jun 30, 2019 9:25 am    Post subject: Kolb-List Digest: 4 Msgs - 06/29/19 Reply with quote
The joystick has a cable pivot point separation of 3" and the elevator controlhorn a cable pivot separation of 4". So we are thinking of increasing the joystickpivot separation to around 4"
Just had another thought.
If you give the eleveator more throw,   it may work like a spoiler,  stall, and make for even less authority than you have now.
Make sure the elevator horn is attached solid with no flex   or movement.   The plans should have listed the maximum movement up and down of the trailing edge of the elevator.
Boyd Young
Mkiii
