KX165 display board
alec(at)alecmyers.com
PostPosted: Thu Jul 04, 2019 5:57 am    Post subject: KX165 display board Reply with quote
Does anyone have a handle on whether it’s possible (and easy) to exchange the display from a KX155 (display works) to a KX165 (display missing some segments)?
Both 28V.
skywagon185(at)gmail.com
PostPosted: Thu Jul 04, 2019 1:03 pm    Post subject: KX165 display board Reply with quote
I have swapped out bad (missing segments) glass display "panels" for the
KX155 and it is quite easy once the front panel is removed. I have not
done same to a KX165, but I suspect it would be the same. And, I would
assume the displays maybe the same. . .
One note... be sure to have the front panel knobs set to some known
position before removing same, so on reassembly you get them indexed
correctly.
The glass display slips into a friction type long socket. Nothing elaborate
PostPosted: Fri Jul 05, 2019 6:51 am    Post subject: KX165 display board Reply with quote
PostPosted: Fri Jul 05, 2019 6:52 am    Post subject: KX165 display board Reply with quote
