3benny3
Posted: Sun Sep 22, 2019 6:13 pm Post subject: Rear wing mount universal fitting play? Tail shake? |
How much if any play (can pick up rear of wing by rear mount 1/4in) play is in the castle nut the bolts universal to the fuselage frame and from universal to wing. Another notch on the castle nut is too tight, while where it is, is to lose I believe. Thinking about using very thin washers to get a "half notch" on the nut. Anyone else have play here, if so how much?
On another note, seems like everyone's horizontal and vertical stab have some flutter/vibration in them. How much do you have if any and how much is ok? Anything you have done to help stabilize/stiffen this area?
_________________ 912 King Kolbra
NC27 |
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Sun Sep 22, 2019 7:21 pm Post subject: Re: Rear wing mount universal fitting play? Tail shake? |
Not exactly sure of what your question is asking, but here are some things I have learned:
You can scrounge/create a very thin washer to put under your rear universal joint big castellated nut and get the play down to very minimal.
You can fit as many washers as you need around the fitting that comes out of the wing root rib & joins said universal fitting to take up virtually all the slack.
Keep fooling around with it, while mine is not totally tight, play is probably less than 1/16", and in flight, is unnoticeable.
If your tail cables are tight, flutter in the horizontal stab will be unnoticable. All Kolb vertical stabs/rudders have slow pulse flutter in them, if you take your feet off the rubber pedals the rudder will start to flap. So keep your feet on the pedals!
Or put a counterweight on your rudder similar to what Kolb sells for the ailerons. Like this:
http://oh2fly.net/oldpoops/pg6.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
3benny3
Posted: Mon Sep 23, 2019 6:07 pm Post subject: Re: Rear wing mount universal fitting play? Tail shake? |
Yeah I think that mostly answers my questions. I don't really feel the play in the air, but anything that moves will wear or wear faster so I'd prefer it be right/tight. My wires are fairly tight and bolted as I never really fold it.
Universal play: https://photos.app.goo.gl/7jw5uTUmbRkyqAyR7
NC27 |
Richard Pike
Posted: Tue Sep 24, 2019 5:02 am Post subject: Re: Rear wing mount universal fitting play? Tail shake? |
After watching your video, I checked the MKIII and the Firefly, the MKIII fittings move a little less than your video, one side of the Firefly just barely moves and the other side does not move at all.
Kingsport, TN 3TN0
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Mon Sep 30, 2019 10:54 am Post subject: Re: Rear wing mount universal fitting play? Tail shake? |
3benny3,
As far as I can tell from the video, the left side seems a little excessive. The right side seems fairly normal. As others have said, you can make a custom washer to take the slop out. You will find that it will still fold just fine if it is pretty tight and well lubricated. I have many hours with varying degrees of looseness in those fittings with no ill effects. I check it on preflight but have only adjusted out the slop twice in 700hrs. I fold every time I fly.
If you think about it, that fitting is always loaded in one direction when flying unless you are pulling negative g, or in really turbulent conditions. It will get the most wear taxiing on rough ground.
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
