throttle setup
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
taildrags
PostPosted: Sun Nov 24, 2019 11:39 am    Post subject: throttle setup Reply with quote
G'day, Pietenpolers;
In an effort to get a Piet thread bumped to the top of the topics list instead of the annual list support threads (I already made my annual contribution to Matronics, thank you Matt), I'm throwing out a general question about throttle setups. I don't like the setup on my airplane and am going to start from scratch. To describe what I have, it's a Bowden cable running from the rear cockpit to the carb. In the front cockpit, a wooden sewing thread bobbin with the edges rounded off has been slipped over the center wire with bug nuts clamping each side of it to the center wire to let the front cockpit occupant slide it back and forth to work the throttle. The setup looks pretty cheesy, but since it's tucked in pretty tight under the top edge of the cockpit, I've never had a passenger snag it or bump it while getting in or out. Other than that, not much else good about it.
In the rear cockpit, a simple flat aluminum lever with the pivot point at the bottom and a round knob up near the top coaming works the throttle. It's pretty cheesy too, but what I like is that I can rest my left hand on the coaming and use my fingertips to work the throttle. It's very stable and easy to make small changes in engine power that way, especially on a bumpy afternoon. Since the knob is up near the coaming rather than down further, I can also reach in and work the throttle very easily from outside the cockpit while prop-starting. It also has enough friction and drag in the cables and lever where I can set throttle in cruise and rarely have it back off or creep off of the RPM that I want.
So what I'm looking for are pix or ideas on how you set up your throttle(s). I've looked through some of the setups in Westcoastpiet. I've already decided to link the front and rear throttles with a rod rather than with the Bowden cable, but other than that, I'm open to ideas. The builder routed the throttle cable inside the cockpit, not outside between the plywood and fabric, so I can get to all of it if I choose to. Thanks.
Oscar Zuniga
Medford, OR
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
oldbird
PostPosted: Mon Nov 25, 2019 6:11 am    Post subject: throttle setup Reply with quote
Hi Oscar
I made my throttle levers as in the picture. Front and rear are identical, connected with solid rod. A bowden cable, actually marine throttle or gearshift linkage, runs from the rear lever to the carb, inside wall of the cockpits. The size of the bowden is the same as the piper's, but since it is marine, it is all in stainless steel.
Cheers
Semih Oksay, Istanbul, Turkey (Now in Orlando,Fl)
On Sun, Nov 24, 2019 at 2:42 PM taildrags <taildrags(at)hotmail.com (taildrags(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "taildrags" <taildrags(at)hotmail.com (taildrags(at)hotmail.com)>
Oscar Zuniga
Medford, OR
Oscar Zuniga
Medford, OR
Air Camper NX41CC &quot;Scout&quot;
http://forums.matronics.com/viewtopic.php?p=493401#493401
br> fts!)
r> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
          -Matt Dralle, List Admin.
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
FORUMS -
WIKI -
b Site -
Semih Oksay
 Filesize:  62.77 KB
 Viewed:  2250 Time(s)
tsts4
PostPosted: Mon Nov 25, 2019 11:14 am    Post subject: Re: throttle setup Reply with quote
Semih, was there a particular reason you ran your Bowden cable from the rear throttle lever instead of the front lever?
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
tkreiner
PostPosted: Sat Nov 30, 2019 6:15 pm    Post subject: Re: throttle setup Reply with quote
Oscar,
Like you, I’m planning on a rod linking the front and rear throttle handles together, with a Bowden cable to the carb.
Speaking of Bowden cables, I made a nice find that I’d like to share with all. I came across a Bernard MIG Liner, thru which MIG welding wire is fed by the welder.
I picked up a 15’ long liner locally for $10. Not bad considering that ACS is getting over $2.00 per foot. This is a Bowden cable that accepts 1/16 SS wire, rather than the .078 wire. Maybe the best part about it is that it is roughly half the weight of the ACS cable.
This Bowden cable will accept either 1/16 (.062) or 1.5mm SS wire. After an exhaustive search, I found 1.5mm SS half hard wire on eBay for roughly $6.75 for 5 meters.
I’m planning to use this for throttle, mixture, and carb heat.
Tom Kreiner
taildrags
PostPosted: Sat Nov 30, 2019 8:05 pm    Post subject: Re: throttle setup Reply with quote
Tom; thanks. I'll look into that MIG liner. For the wire, my starting point is always McMaster-Carr. A quick search on their site finds a 27 ft length of .059" (about 1.5mm) "spring back" 304 stainless wire for $5.03, but they have lots of others to choose from. I think for the throttle I'd go heavier than more slender just to avoid the possibility of kinking the wire on a quick full throttle advance.
-Oscar
Oscar Zuniga
Medford, OR
gjkaal
PostPosted: Mon Dec 02, 2019 12:11 pm    Post subject: throttle setup Reply with quote
Nice! Once you know, what you're looking for, things get simpler. Never thought about searching for MIG Liner:
https://nl.aliexpress.com/item/32719611456.html?spm=a2g0z.12010612.8148356.23.7f4b4ac0uqMDw2
Ordered 2 sets of 4m (12ft) for €12,50 ...
On Sun, 1 Dec 2019 at 03:19, tkreiner <tkreiner(at)gmail.com (tkreiner(at)gmail.com)> wrote:
--> Pietenpol-List message posted by: "tkreiner" <tkreiner(at)gmail.com (tkreiner(at)gmail.com)>
Oscar,
Tom Kreiner
http://forums.matronics.com/viewtopic.php?p=493692#493692
br> fts!)
FORUMS -
WIKI -
b Site -
GJH Kaal
Building a Pietenpol air camper
oldbird
PostPosted: Mon Dec 02, 2019 4:25 pm    Post subject: throttle setup Reply with quote
I have played with MIG for 25 years and never thought of using the liner as throttle cable. The marine throttle cables for especially outboard motors are the same dimension with the Piper throttle cables, almost any length. More durable and reliable I think. Their ends are just the same as Piper throttle cables.
my 2 cents
Semih Oksay, building in Istanbul, Turkey, now in Orlando,Fl
On Mon, Dec 2, 2019 at 3:18 PM Gerrit-Jan Kaal <gjhkaal(at)gmail.com (gjhkaal(at)gmail.com)> wrote:
Oscar,
Tom Kreiner
br> fts!)
FORUMS -
WIKI -
b Site -
Semih Oksay
jarheadpilot82
PostPosted: Thu Dec 12, 2019 11:40 am    Post subject: Re: throttle setup Reply with quote
Todd,
I know that you wrote this a while back, but since nobody has answered your question, I thought that I would chime in.
If (God forbid) your throttle cable came loose from the throttle handle in the rear, what would you be able to do to control the throttle? Not easily, but I think that you stand a chance of being able to move the throttle cable enough while loose to make an emergency landing.
If it disconnects from the throttle in the front seat, what you can you do about it from the rear? Not a blessed thing.
At least that is my reasoning for attaching the cable directly to the rear throttle.
YMMV.
Semper Fi,
Terry Hand
Athens, GA
taildrags
PostPosted: Thu Dec 12, 2019 8:32 pm    Post subject: Re: throttle setup Reply with quote
Well now Terry, that makes a heck of a lot of sense! It also makes it possible to disconnect (or remove) the throttle from the front cockpit along with the stick, if they are constructed to be removed, without disturbing the pilot's operation of the throttle. This is sometimes useful when you are giving rides and don't want anyone working the controls who shouldn't be, and also removes some obstacles that passengers sometimes have to work around while climbing in and out.
Oscar Zuniga
Medford, OR
tsts4
PostPosted: Fri Dec 13, 2019 3:51 am    Post subject: Re: throttle setup Reply with quote
Well I'm not sold on that configuration but that's the beauty of E-AB, each builder gets to decide on things like this. I much prefer the setup that most tandem seat aircraft use which is a rod linkage between the throttle levers and a cable from the front lever to the carb (and I get that most are soloed from the front seat). The attached pics are of a J3 Cub (the 2nd one is a close up of the front throttle). Using proper construction procedures I feel the risk of a disconnect as you describe is minimal. Plus trying to manipulate a broken cable as suggested and fly the plane is going to be difficult at best. I'd rather fly to a suitable airport/field, set up for an approach and kill the engine by shutting the fuel off once the landing is assured. YMMV....
 Filesize:  116.51 KB
 Viewed:  1964 Time(s)
 Filesize:  111.99 KB
 Viewed:  1957 Time(s)
Todd Stovall
jarheadpilot82
PostPosted: Mon Dec 16, 2019 3:12 pm    Post subject: Re: throttle setup Reply with quote
Todd,
Your plan to kill the engine and deadstick it in is a good one - provided the cable did not come loose when you were at idle or a reduced power setting. Then your likelihood of getting to anywhere but what is directly below you is greatly diminished if you can't reach the throttle cable. I did not say that my plan was optimal, but it does give you a chance to do what you said, adjust the cable to full forward throttle, fly to a field, cutoff the engine and deadstick it in.
But as you said, it is experimental aviation, and you can build your airplane any way that you see fit. I am just encouraging you from a risk management standpoint to rethink where you will connect your throttle cable.
Semper Fi,
Terry Hand
Athens, GA
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
