KY97A connector
rasmussenre(at)gmail.com
PostPosted: Fri Feb 07, 2020 11:41 am    Post subject: KY97A connector Reply with quote
Greetings All,
Anyone know where I can get a 30 pin “edge connector” for a KY97A?
Robert
~ 1 2 3 4 5 6 7 8 9 10 1112 1314 15
FRONT VIEW - CONNECTOR
(AS SEEN IF VIEWING FROM THE FRONT OF THE RACK)
H -------------- - 500 0 AUDIO HI
7 ----------- 500 0 AUDIO LO
J - ---------- MIC AUDIO HI
K - ---------- MIC INTERCOM
9 - ------- MICKEY
8 ------------- MIC AUDIO LO
1 0 - ------------- SQUELCH AND COMPRESSOR DISABLE
l - -------------- AGC TEST /REMOTE CHANNEL INC
1 1 - ------------ + 1 3. 7 5 VDC POWER
M - ------------- + 1 3. 75 VDC POWER
R- ------------- AIRCRAFT POWER +13.75 VDC
14- ------- AIRCRAFT POWER +13.75 VDC
P --------- - SWITCHED AIRCRAFT POWER
1 3 ------------ - SWITCHED AIRCRAFT POWER
N - ------------- XMIT REC INTERLOCK
12 - ----------------------- REMOTE TRANSFER
F ---------------------- AIRCRAFT GROUND
6 ----------------------- AIRCRAFT GROUND
S ------------------ AIRCRAFT GROUND
15 ---------------------- AIRCRAFT GROUND
B - ----------------- + 14VDC LIGHTING HI
1 ----------------- LIGHTING LO
2 ------------ - DETECTED AUDIO OUT
A ---------------DIM SELECT
E -------------- - 40 AUDIO OUT
5 -------------- 40 AUDIO LO
D - ------------ AUX AUDIO IN 1
C - ------------- AUX AUDIO IN 2
3 - ----------- AUX AUDIO IN 3
4 ---------------- AUX AUDIO IN LO
rulmen
PostPosted: Fri Feb 07, 2020 12:00 pm    Post subject: KY97A connector Reply with quote
I have one. EmAil me
On Feb 7, 2020, at 2:47 PM, rasmussenRE <rasmussenre(at)gmail.com> wrote:
 <![endif]--> <![endif]-->
Greetings All,
Robert
9 - ------- MICKEY
RULMEN
ceengland7(at)gmail.com
PostPosted: Fri Feb 07, 2020 12:13 pm    Post subject: KY97A connector Reply with quote
I don't know the radio, but if it's an old pc board edge connector, this might be worth some research:
https://www.aircraftspruce.com/catalog/avpages/icoma210connector.php?gclid=CjwKCAiA35rxBRAWEiwADqB377qMQ_OVPp-pqBnsl54hJisWD2Zq76_qewNSDDA7eiT6cYCZIGTFjhoCQDUQAvD_BwE
You'd need to verify center-center spacing of the tabs, and overall edge width. This link might be worth  a read as kind of a 'back door' reference:
http://www.vansairforce.com/community/showthread.php?p=1354743
Charlie
On Fri, Feb 7, 2020 at 1:47 PM rasmussenRE <rasmussenre(at)gmail.com (rasmussenre(at)gmail.com)> wrote:
Greetings All,
Robert
9 - ------- MICKEY
