SL30 Serial Connection
Dan Fritz
PostPosted: Fri Apr 03, 2020 7:41 am    Post subject: SL30 Serial Connection Reply with quote
Hello all, I’m wiring up my panel and connecting an SL30 nav/com to my MGL iEFIS. It appears my SL30 is not transmitting over the RS-232 serial line to the iEFIS, so I checked my wiring and it appears the SL30 has its serial transmit line internally grounded. This doesn’t appear correct to me, but before sending the unit back to Garmin for repair$, I thought I’d see if anyone here on the list has seen this before and could give any advice.
Thanks in advance,
Dan
