Connector Shells
neal.george(at)gmail.com
PostPosted: Thu Jun 04, 2020 10:49 am    Post subject: Connector Shells Reply with quote
Gentlemen -
I need some of the metal connector shells for a GNS530.
Anybody have part number equivalents for Digikey, Mouser, etc?
Neal George
PostPosted: Fri Jun 05, 2020 1:08 pm    Post subject: Connector Shells Reply with quote
What genre' of connector? I was thinking they were
high density d-subs?
I'll dig around in my install manuals and see
if I can confirm.
ceengland7(at)gmail.com
PostPosted: Fri Jun 05, 2020 3:46 pm    Post subject: Connector Shells Reply with quote
if I can confirm.
The 430 has both std & hi density connectors. the stock backshells are apparently available from only one or two sources. Here's an ebay listing with a pretty good pic:
https://www.ebay.com/itm/GNS430-GNS430W-GNS530-GNS530W-Connector-Kits-011-00351-00-/143440923345?_trksid=p2385738.m4383.l4275.c10
In my not so humble opinion, the backplane/connector arrangement is almost enough reason, by itself, to avoid Garmin. A real nightmare dealing with the tiny screws using a foot long screwdriver reaching into the back of the tray...
Charlie
alec(at)alecmyers.com
PostPosted: Fri Jun 05, 2020 4:00 pm    Post subject: Connector Shells Reply with quote
Looking at one I have left over from an Avidyne install, here’s the mouser page for the connector. I’m pretty sure you can track down the back shell from this:
https://www.mouser.ca/ProductDetail/TE-Connectivity/204521-2
TE part code 204521-2
On Jun 4, 2020, at 14:50, Neal George <neal.george(at)gmail.com> wrote:
--> AeroElectric-List message posted by: Neal George <neal.george(at)gmail.com>
Gentlemen -
Neal Georg==========================bsp; - The AeroElectric-List Email ====================================================; - MATRONICS WEB FORUMS -
PostPosted: Fri Jun 05, 2020 4:09 pm    Post subject: Connector Shells Reply with quote
Here’s a size 5 back shell that would fit the 78 pin connector:
https://www.mouser.ca/ProductDetail/Amphenol-Pcd/M85049-48-2-5F?qs=GaJ26EWJkZTRGEGAZKUsJA%3D%3D
I’m fairly sure the shell sizes are standard so you can mix and match. At the least, the dimensioned drawings are available to check.
Gentlemen -
PostPosted: Fri Jun 05, 2020 4:49 pm    Post subject: Connector Shells Reply with quote
Agreed, but we’re stuck with it for now. Found a connector kit on eBay...
Neal GeorgeSent from my iPhone
if I can confirm.
Charlie
stein(at)steinair.com
PostPosted: Sat Jun 06, 2020 8:40 am    Post subject: Connector Shells Reply with quote
Well…It’s hardly a singular Garmin issue, as they are the same on Avidyne, (as well as Bendix King, Narco, L3, PSE, etc..) so if you are all about avoiding using a long screwdriver to remove the backplate and/or connectors you’re not left with much choice of avionics.
The newer generation stuff is much better, but much of the older generation stuff is a pain (regardless of brand).
Cheers,
Stein
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of Charlie England
Sent: Friday, June 5, 2020 6:43 PM
Subject: Re: Connector Shells
Charlie
Virus-free. www.avast.com
