MTV propeller replacement springs
PostPosted: Mon Jun 29, 2020 7:33 pm    Post subject: MTV propeller replacement springs Reply with quote
As I understand, there are two springs that need to be replaced for raising the oil pressure when installing an MTV propeller. I assume one of them is at the back of the R2 governor's oil pump? Where does the second one go?
I don't intend to change them myself - just want to know.
Also, is there any danger in overspeeding the engine when changing these springs (considering they just raise the pressure)?
Thank you.
richard.goode(at)russiana
PostPosted: Mon Jun 29, 2020 11:42 pm    Post subject: MTV propeller replacement springs Reply with quote
You need to remove the top of the governor in order to replace the two oil
pressure springs.
But, it is the reverse of what you're suggesting. There is less danger of
overspeeding with high oil pressure.
Richard
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel:  +44 (0)1544 340120   Fax:  +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
